RTEMS 6.1-rc2
uart_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _UART_DMA_
38#define _UART_DMA_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "chip.h"
45
46/*----------------------------------------------------------------------------
47 * Definitions
48 *----------------------------------------------------------------------------*/
49
51#define UARTD_ERROR 1
52
54#define UARTD_ERROR_LOCK 2
55
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61/*----------------------------------------------------------------------------
62 * Types
63 *----------------------------------------------------------------------------*/
64
66typedef void (*UartdCallback)(uint8_t, void *);
67
73typedef struct {
75 uint8_t *pBuff;
77 uint32_t BuffSize;
79 uint32_t ChNum;
83 void *pArgument;
85 volatile uint8_t sempaphore;
86 /* DMA LLI structure */
88 /* DMA transfer type */
89 eXdmadProgState dmaProgrammingMode;
90 /* DMA LLI size */
91 uint16_t dmaBlockSize;
92 /* Flag using ring buffer or FiFo*/
93 uint8_t dmaRingBuffer;
95
98typedef struct {
100 uint8_t uartId;
109} UartDma;
110
111/*----------------------------------------------------------------------------
112 * Exported functions
113 *----------------------------------------------------------------------------*/
114
115uint32_t UARTD_Configure(UartDma *pUartd ,
116 uint8_t uartId,
117 uint32_t uartMode,
118 uint32_t baud,
119 uint32_t clk);
120
121uint32_t UARTD_EnableTxChannels(UartDma *pUartd, UartChannel *pTxCh);
122
123uint32_t UARTD_EnableRxChannels(UartDma *pUartd, UartChannel *pRxCh);
124
125uint32_t UARTD_DisableTxChannels(UartDma *pUartd, UartChannel *pTxCh);
126
127uint32_t UARTD_DisableRxChannels(UartDma *pUartd, UartChannel *pRxCh);
128
129uint32_t UARTD_SendData(UartDma *pUartd);
130
131uint32_t UARTD_RcvData(UartDma *pUartd);
132
133#ifdef __cplusplus
134}
135#endif
136
137#endif /* #ifndef _UART_DMA_ */
enum _XdmadProgState eXdmadProgState
usart Transfer Request prepared by the application upper layer.
Definition: uart_dma.h:73
void * pArgument
Definition: uart_dma.h:83
UartdCallback callback
Definition: uart_dma.h:81
uint32_t BuffSize
Definition: uart_dma.h:77
Definition: uart_dma.h:85
uint8_t * pBuff
Definition: uart_dma.h:75
uint32_t ChNum
Definition: uart_dma.h:79
Definition: uart_dma.h:98
Uart * pUartHw
Definition: uart_dma.h:104
UartChannel * pTxChannel
Definition: uart_dma.h:108
UartChannel * pRxChannel
Definition: uart_dma.h:106
sXdmad * pXdmad
Definition: uart_dma.h:102
uint8_t uartId
Definition: uart_dma.h:100
Uart hardware registers.
Definition: component_uart.h:41
Structure for storing parameters for DMA view1 that can be performed by the DMA Master transfer.
Definition: xdmad.h:167
Definition: xdmad.h:127
This function disables the appropriate DMA channel for Rx channel of USART.
Definition: uart_dma.c:517
void(* UartdCallback)(uint8_t, void *)
Definition: uart_dma.h:66
Starts a UART master transfer. This is a non blocking function. It will return as soon as the transfe...
Definition: uart_dma.c:585
This function initialize the appropriate DMA channel for Rx channel of UART.
Definition: uart_dma.c:409
This function initialize the appropriate DMA channel for Tx channel of UART.
Definition: uart_dma.c:464
uint32_t UARTD_Configure(UartDma *pUartd, uint8_t uartId, uint32_t uartMode, uint32_t baud, uint32_t clk)
Initializes the UartDma structure and the corresponding UART & DMA . hardware select value....
Definition: uart_dma.c:360
This function disables the appropriate DMA channel for Tx channel of USART.
Definition: uart_dma.c:552
Definition: uart_dma.c:607
