RTEMS 6.1-rc2
tftpfs_interactions.c File Reference
This source file contains the implementation of network interaction functions related to the UDP network fake for tftpfs testing. More...
#include <inttypes.h>
#include <arpa/inet.h>
#include <rtems/test.h>
#include "tftpfs_interactions.h"
#include "tftpfs_udp_network_fake.h"
struct  interaction_data_socket
struct  interaction_data_close
struct  interaction_data_bind
struct  interaction_data_sendto
struct  interaction_data_recvfrom
#define TFTP_MAX_FILENAME_STRLEN   12
typedef struct interaction_data_socket interaction_data_socket
typedef struct interaction_data_close interaction_data_close
typedef struct interaction_data_bind interaction_data_bind
typedef struct interaction_data_sendto interaction_data_sendto
typedef struct interaction_data_recvfrom interaction_data_recvfrom
void _Tftp_Add_interaction_socket (int domain, int type, int protocol, int result)
void _Tftp_Add_interaction_close (int fd, int result)
void _Tftp_Add_interaction_bind (int fd, int family, int result)
void _Tftp_Add_interaction_send_rrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result)
void _Tftp_Add_interaction_send_wrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result)
void _Tftp_Add_interaction_send_ack (int fd, uint16_t block_num, uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_send_data (int fd, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_send_error (int fd, uint16_t error_code, uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_recv_data (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), bool result)
void _Tftp_Add_interaction_recv_ack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, bool result)
void _Tftp_Add_interaction_recv_oack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, const char *options, size_t options_size, bool result)
void _Tftp_Add_interaction_recv_error (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t error_code, const char *err_msg, bool result)
void _Tftp_Add_interaction_recv_raw (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, size_t len, const uint8_t *bytes, bool result)
void _Tftp_Add_interaction_recv_nothing (int fd, uint32_t timeout_ms)
The UDP Network Fake requires interactions between TFTP client and test (which emulates a TFTP server). The idea is that each test defines a sequence of interactions. In a successful test run all interactions must be carried out one-by-one till the last interaction is reached.
Interactions appear when the TFTP client calls functions like sendto(), recvfrom(), or socket(). Here functions are defined which
