RTEMS 6.1-rc2
interaction_data_sendto Struct Reference
int fd
uint16_t dest_port
char dest_addr_str [TFTP_MAX_IP_ADDR_STRLEN]
bool result
union {
   struct {
      uint16_t   opcode
      char   filename [TFTP_MAX_FILENAME_STRLEN]
      uint16_t   block_size
      uint16_t   window_size
   }   rwrq
   struct {
      uint16_t   block_num
   }   ack
   struct {
      uint16_t   block_num
      size_t   start
      size_t   len
      uint8_t(*   get_data )(size_t pos)
   }   data
   struct {
      uint16_t   error_code
   }   error
content
