RTEMS 6.1-rc2
tms570_selftest_par_desc Struct Reference
#include <tms570_selftest_parity.h>
unsigned char esm_prim_grp
unsigned char esm_prim_chan
unsigned char esm_sec_grp
unsigned char esm_sec_chan
int fail_code
volatile uint32_t * ram_loc
volatile uint32_t * par_loc
uint32_t par_xor
volatile uint32_t * par_cr_reg
uint32_t par_cr_test
volatile uint32_t * par_st_reg
uint32_t par_st_clear
tms570_selftest_par_fnc_t * partest_fnc
volatile void * fnc_data
Decriptor specifying registers addresses and values used to test that parity protection is working for given hardware module/peripheral. It is used during initial chip self-tests.
Field Documentation
◆ esm_prim_chan
unsigned char tms570_selftest_par_desc::esm_prim_chan
ESM primary signalling channel number.
◆ esm_prim_grp
unsigned char tms570_selftest_par_desc::esm_prim_grp
ESM primary signalling group number.
◆ esm_sec_chan
unsigned char tms570_selftest_par_desc::esm_sec_chan
ESM optional/alternative signalling channel.
◆ esm_sec_grp
unsigned char tms570_selftest_par_desc::esm_sec_grp
ESM optional/alternative signalling group.
◆ fail_code
int tms570_selftest_par_desc::fail_code
Error code reported to bsp_selftest_fail_notification() in the case of the test failure.
◆ fnc_data
volatile void* tms570_selftest_par_desc::fnc_data
Pointer to the base of tested peripheral registers. It is required by some test functions (CAN and MibSPI)
◆ par_cr_reg
volatile uint32_t* tms570_selftest_par_desc::par_cr_reg
Address of module parity test control register.
◆ par_cr_test
uint32_t tms570_selftest_par_desc::par_cr_test
Mask of bit which cause switch to a test mode.
◆ par_loc
volatile uint32_t* tms570_selftest_par_desc::par_loc
Address of mapping of parity bits into CPU address space.
◆ par_st_clear
uint32_t tms570_selftest_par_desc::par_st_clear
Optional value which is written to status register to clear error.
◆ par_st_reg
volatile uint32_t* tms570_selftest_par_desc::par_st_reg
Optional module parity status register which.
◆ par_xor
uint32_t tms570_selftest_par_desc::par_xor
Bitmask used to alter parity to cause intentional parity failure.
◆ partest_fnc
tms570_selftest_par_fnc_t* tms570_selftest_par_desc::partest_fnc
Function which specialized for given kind of peripheral/module mechanism testing.
◆ ram_loc
volatile uint32_t* tms570_selftest_par_desc::ram_loc
Address of memory protected by parity.
