RTEMS 6.1-rc2
This structure represents TFTP options negotiated between client and server. More...
#include <tftp.h>
Data Fields | |
uint16_t | block_size |
This member represents the desired size of a data block. | |
uint16_t | window_size |
This member represents the desired size of a window. | |
RFC 2347 is the basis for the TFTP option.
uint16_t tftp_options::block_size |
The TFTP blocksize option is introduced in RFC 2348. It defines the number of octets in the data packets transferred. Valid values range between 8 and 65464 octets, inclusive. Values larger than 1468 may cause packet fragmentation over standard Ethernet. A value of 512 will prevent this option from being sent to the server.
The default value is 1456.
uint16_t tftp_options::window_size |
The TFTP windowsize option is introduced in RFC 7440. It defines the number of data packets send before the receiver must send an acknowledgment packet. Valid values range between 1 and 65535 packets, inclusive. Simple TFTP servers usually do not support this option. This option may negatively contribute to network congestion. This can be avoided by using a window size of 1. A value of 1 will prevent this option from being sent to the server.
The default value is 8.
