SPI bus control.
More...
#include <spi.h>
int(* | transfer )(spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count) |
| Transfers SPI messages.
int(* | setup )(spi_bus *bus) |
| Checks if maximum speed and bits per word are in a valid range for the device.
void(* | destroy )(spi_bus *bus) |
| Destroys the bus.
rtems_recursive_mutex | mutex |
| Mutex to protect the bus access.
uint32_t | max_speed_hz |
| Maximum Speed in Hz.
uint32_t | speed_hz |
| Indicates the speed of the current device message.
bool | cs_change |
| Indicates if chip select must be set high after transfer.
uint8_t | cs |
| Indicates which device is selected by chip select.
uint8_t | bits_per_word |
| Indicates the bits per word used on the device.
bool | lsb_first |
| Indicates if LSB is supposed to be transmitted first.
uint32_t | mode |
| Current mode.
uint16_t | delay_usecs |
| Indicates the delay between transfers on different chip select devices.
int(* | ioctl )(spi_bus *bus, ioctl_command_t command, void *arg) |
| Driver specific ioctl.
◆ destroy
void(* spi_bus::destroy) (spi_bus *bus) |
Destroys the bus.
- Parameters
◆ ioctl
int(* spi_bus::ioctl) (spi_bus *bus, ioctl_command_t command, void *arg) |
- Parameters
◆ setup
int(* spi_bus::setup) (spi_bus *bus) |
- Parameters
- Return values
0 | Successful operation. |
negative | Negative error number in case of an error. |
◆ transfer
- Parameters
[in] | bus | The bus control. |
[in] | msgs | The messages to transfer. |
[in] | msg_count | The count of messages to transfer. It must be positive. |
- Return values
- cpukit/include/dev/spi/spi.h
