RTEMS 6.1-rc2
sc16is752_spi_context Struct Reference
SC16IS752 SPI context. More...
#include <sc16is752.h>
sc16is752_context base
int fd
 The SPI bus device file descriptor.
uint8_t cs
 The SPI device chip select.
uint32_t speed_hz
 The SPI bus speed in Hertz.
const char * spi_path
 The SPI bus device path.
Field Documentation
◆ cs
uint8_t sc16is752_spi_context::cs
Must be initialized by the user before the call to sc16is752_spi_create().
◆ fd
int sc16is752_spi_context::fd
Internal variable.
◆ speed_hz
uint32_t sc16is752_spi_context::speed_hz
◆ spi_path
const char* sc16is752_spi_context::spi_path
