RTEMS 6.1-rc2
rtems_stack_checker_info Struct Reference
This structure contains the stack information provided by the stack checker for a stack. More...
#include <stackchk.h>
rtems_id id
 This member contains the object identifier associated with the object using the stack.
const char * name
 This member provides the object name associated with the object using the stack.
const void * begin
 This member provides the begin address of the stack area.
uintptr_t size
 This member contains the size in byes of the stack area.
const void * current
 This member provides the current stack pointer of the stack.
uintptr_t used
 This member contains the size in byes of the used stack area.
Field Documentation
◆ current
const void* rtems_stack_checker_info::current
If the current stack pointer is not available, then the value is set to NULL.
◆ id
rtems_id rtems_stack_checker_info::id
For interrupt stacks, the object identifier is the processor index.
◆ name
const char* rtems_stack_checker_info::name
For interrupt stacks, the object name is "Interrupt Stack".
◆ used
uintptr_t rtems_stack_checker_info::used
If the stack checker is not initialized, then the value is set to UINTPTR_MAX.
