RTEMS 6.1-rc2
rtems_rtl_obj_sect_finder Struct Reference
rtems_rtl_obj_sectsect
const char * name
int index
uint32_t mask
unsigned int flags
Section finder iterator data.
Field Documentation
◆ flags
unsigned int rtems_rtl_obj_sect_finder::flags
The flags to use when matching.
◆ index
int rtems_rtl_obj_sect_finder::index
The index to match.
◆ mask
uint32_t rtems_rtl_obj_sect_finder::mask
The mask to match.
◆ name
const char* rtems_rtl_obj_sect_finder::name
The name to match.
◆ sect
rtems_rtl_obj_sect* rtems_rtl_obj_sect_finder::sect
The matching section.
