RTEMS 6.1-rc2
rtems_ftpfs_entry Struct Reference
off_t file_size
int ctrl_socket
uint32_t client_address
int data_socket
size_t reply_current
size_t reply_end
char reply_buffer [128]
bool eof
bool write
bool do_size_command
ino_t ino
const char * user
const char * password
const char * hostname
const char * filename
char buffer []
Connection entry for each open file stream.
Field Documentation
◆ ctrl_socket
int rtems_ftpfs_entry::ctrl_socket
Control connection socket.
◆ data_socket
int rtems_ftpfs_entry::data_socket
Data transfer socket.
◆ do_size_command
bool rtems_ftpfs_entry::do_size_command
Indicates if we should do a SIZE command.
The first call to the rtems_ftpfs_fstat() handler is issued by the path evaluation to check for access permission. For this case we avoid the SIZE command.
◆ eof
bool rtems_ftpfs_entry::eof
End of file flag.
◆ reply_buffer
char rtems_ftpfs_entry::reply_buffer[128]
Buffer for relpy data.
◆ reply_current
size_t rtems_ftpfs_entry::reply_current
Current index into the reply buffer.
◆ reply_end
size_t rtems_ftpfs_entry::reply_end
End index of the reply buffer.
