RTEMS 6.1-rc2
rtems_fdisk_segment_ctl Struct Reference
struct rtems_fdisk_segment_ctlnext
const rtems_fdisk_segment_descdescriptor
uint32_t device
uint32_t segment
rtems_fdisk_page_descpage_descriptors
uint32_t pages
uint32_t pages_desc
uint32_t pages_active
uint32_t pages_used
uint32_t pages_bad
uint32_t failed
uint32_t erased
Flash Segment Control holds the pointer to the segment, number of pages, various page stats and the memory copy of the page descriptors.
Field Documentation
◆ descriptor
const rtems_fdisk_segment_desc* rtems_fdisk_segment_ctl::descriptor
The descriptor provided by the low-level driver.
◆ device
uint32_t rtems_fdisk_segment_ctl::device
The device this segment resides on.
◆ erased
uint32_t rtems_fdisk_segment_ctl::erased
Counter to debugging. Wear support would remove this.
◆ failed
uint32_t rtems_fdisk_segment_ctl::failed
The segment has failed.
◆ next
struct rtems_fdisk_segment_ctl* rtems_fdisk_segment_ctl::next
Segments with available pages are maintained as a linked list.
◆ page_descriptors
rtems_fdisk_page_desc* rtems_fdisk_segment_ctl::page_descriptors
The in-memory ocpy of the page descriptors found at the start of the segment in the flash device.
◆ pages
uint32_t rtems_fdisk_segment_ctl::pages
Total number of pages in the segment.
◆ pages_active
uint32_t rtems_fdisk_segment_ctl::pages_active
Number of pages flagged as active.
◆ pages_bad
uint32_t rtems_fdisk_segment_ctl::pages_bad
Number of pages detected as bad.
◆ pages_desc
uint32_t rtems_fdisk_segment_ctl::pages_desc
Number of pages used for page descriptors.
◆ pages_used
uint32_t rtems_fdisk_segment_ctl::pages_used
Number of pages flagged as used.
◆ segment
uint32_t rtems_fdisk_segment_ctl::segment
The segment in the device. This must be within the segment descriptor.
