RTEMS 6.1-rc2
rtems_blkdev_request Struct Reference
The block device transfer request is used to read or write a number of blocks from or to the device. More...
#include <blkdev.h>
rtems_blkdev_request_op req
rtems_blkdev_request_cb done
void * done_arg
rtems_status_code status
uint32_t bufnum
rtems_id io_task
rtems_blkdev_sg_buffer bufs [RTEMS_ZERO_LENGTH_ARRAY]
Transfer requests are issued to the disk device driver with the RTEMS_BLKIO_REQUEST IO control. The transfer request completion status must be signalled with rtems_blkdev_request_done(). This function must be called exactly once per request. The return value of the IO control will be ignored for transfer requests.
See also
rtems_blkdev_create().
Field Documentation
◆ bufnum
uint32_t rtems_blkdev_request::bufnum
Number of blocks for this request.
◆ bufs
rtems_blkdev_sg_buffer rtems_blkdev_request::bufs[RTEMS_ZERO_LENGTH_ARRAY]
List of scatter or gather buffers.
◆ done
rtems_blkdev_request_cb rtems_blkdev_request::done
Request done callback function.
◆ done_arg
void* rtems_blkdev_request::done_arg
Argument to be passed to callback function.
◆ io_task
rtems_id rtems_blkdev_request::io_task
The task requesting the IO operation.
◆ req
rtems_blkdev_request_op rtems_blkdev_request::req
Block device operation (read or write).
◆ status
rtems_status_code rtems_blkdev_request::status
Last IO operation completion status.
