RTEMS 6.1-rc2
rtems_api_configuration_table Struct Reference
This structure contains a summary of the Classic API configuration. More...
#include <config.h>
uint32_t maximum_tasks
 This member contains the maximum number of Classic API Tasks configured for this application.
bool notepads_enabled
 This member is true, if the Classic API Notepads are enabled, otherwise it is false.
uint32_t maximum_timers
 This member contains the maximum number of Classic API Timers configured for this application.
uint32_t maximum_semaphores
 This member contains the maximum number of Classic API Semaphores configured for this application.
uint32_t maximum_message_queues
 This member contains the maximum number of Classic API Message Queues configured for this application.
uint32_t maximum_partitions
 This member contains the maximum number of Classic API Partitions configured for this application.
uint32_t maximum_regions
 This member contains the maximum number of Classic API Regions configured for this application.
uint32_t maximum_ports
 This member contains the maximum number of Classic API Dual-Ported Memories configured for this application.
uint32_t maximum_periods
 This member contains the maximum number of Classic API Rate Monotonic Periods configured for this application.
uint32_t maximum_barriers
 This member contains the maximum number of Classic API Barriers configured for this application.
uint32_t number_of_initialization_tasks
 This member contains the number of Classic API Initialization Tasks configured for this application.
const rtems_initialization_tasks_tableUser_initialization_tasks_table
 This member contains the pointer to Classic API Initialization Tasks Table of this application.
Use rtems_configuration_get_rtems_api_configuration() to get the configuration table.
Field Documentation
◆ maximum_barriers
uint32_t rtems_api_configuration_table::maximum_barriers
See CONFIGURE_MAXIMUM_BARRIERS.
◆ maximum_message_queues
uint32_t rtems_api_configuration_table::maximum_message_queues
See CONFIGURE_MAXIMUM_MESSAGE_QUEUES.
◆ maximum_partitions
uint32_t rtems_api_configuration_table::maximum_partitions
See CONFIGURE_MAXIMUM_PARTITIONS.
◆ maximum_periods
uint32_t rtems_api_configuration_table::maximum_periods
See CONFIGURE_MAXIMUM_PERIODS.
◆ maximum_ports
uint32_t rtems_api_configuration_table::maximum_ports
See CONFIGURE_MAXIMUM_PORTS.
◆ maximum_regions
uint32_t rtems_api_configuration_table::maximum_regions
See CONFIGURE_MAXIMUM_REGIONS.
◆ maximum_semaphores
uint32_t rtems_api_configuration_table::maximum_semaphores
See CONFIGURE_MAXIMUM_SEMAPHORES.
◆ maximum_tasks
uint32_t rtems_api_configuration_table::maximum_tasks
See CONFIGURE_MAXIMUM_TASKS.
◆ maximum_timers
uint32_t rtems_api_configuration_table::maximum_timers
See CONFIGURE_MAXIMUM_TIMERS.
◆ number_of_initialization_tasks
uint32_t rtems_api_configuration_table::number_of_initialization_tasks
See CONFIGURE_RTEMS_INIT_TASKS_TABLE.
◆ User_initialization_tasks_table
const rtems_initialization_tasks_table* rtems_api_configuration_table::User_initialization_tasks_table
