RTEMS 6.1-rc2
System Control Block representation. More...
#include <lpc176x.h>
Data Fields | |
uint32_t | flashcfg |
Flash Accelerator Configuration Register. | |
uint32_t | reserved_04 [15] |
uint32_t | memmap |
Memopry Map Control. | |
uint32_t | reserved_44 [15] |
lpc176x_pll | pll_0 |
Phase-Locked Loop 0. | |
uint32_t | reserved_90 [4] |
lpc176x_pll | pll_1 |
Phase-Locked Loop 1. | |
uint32_t | reserved_b0 [4] |
uint32_t | pcon |
Power Mode Control register. | |
uint32_t | pconp |
Power Control for Peripherals register. | |
uint32_t | reserved_c8 [15] |
uint32_t | cclksel |
Selects the divide valuefor creating the CPU clock from the PPL0 output. | |
uint32_t | usbclksel |
Selects the divide value for creating the USB clock from the PPL0 output. | |
uint32_t | clksrcsel |
Clock Source Select register. | |
uint32_t | reserved_110 [12] |
uint32_t | extint |
External Interrupt flag register. | |
uint32_t | reserved_144 |
uint32_t | extmode |
External Interrupt Mode register. | |
uint32_t | extpolar |
External Interrupt Polarity register. | |
uint32_t | reserved_150 [12] |
uint32_t | rsid |
Reset Source Identification Register. | |
uint32_t | reserved_184 [7] |
uint32_t | scs |
System Controls and Status Register. | |
uint32_t | reserved_1a4 |
uint32_t | pclksel [2] |
Peripheral Clock Selection registers 0 and 1. | |
uint32_t | pboost |
Peripheral boost. | |
uint32_t | reserved_1b4 [5] |
uint32_t | clkoutcfg |
Clock Output Configuration Register. | |
uint32_t | rstcon [2] |
Reset Control bit 0 and 1. | |
uint32_t | reserved_1d4 [4] |
