RTEMS 6.1-rc2
fh_sg_list Struct Reference
#include <fsl_hcalls.h>
uint64_t source
uint64_t target
uint64_t size
uint64_t reserved
struct fh_sg_list: definition of the fh_partition_memcpy S/G list @source: guest physical address to copy from @target: guest physical address to copy to @size: number of bytes to copy @reserved: reserved, must be zero
The scatter/gather list for fh_partition_memcpy() is an array of these structures. The array must be guest physically contiguous.
This structure must be aligned on 32-byte boundary, so that no single strucuture can span two pages.
Field Documentation
◆ reserved
uint64_t fh_sg_list::reserved
◆ size
uint64_t fh_sg_list::size
◆ source
uint64_t fh_sg_list::source
◆ target
uint64_t fh_sg_list::target
