RTEMS 6.1-rc2
drvmgr_drv_ops Struct Reference
#include <drvmgr.h>
int(* init [DRVMGR_LEVEL_MAX])(struct drvmgr_dev *)
int(* remove )(struct drvmgr_dev *)
int(* info )(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
Driver operations, function pointers.
Field Documentation
◆ info
int(* drvmgr_drv_ops::info) (struct drvmgr_dev *, void(*print)(void *p, char *str), void *p, int, char *argv[])
Function called when device instance is to be removed
◆ remove
int(* drvmgr_drv_ops::remove) (struct drvmgr_dev *)
Function doing Init Stage 1 of a hardware device
