RTEMS 6.1-rc2
_xecc_config Struct Reference
XECC user configuration. More...
#include <fsl_xecc.h>
bool enableXECC
bool enableWriteECC
bool enableReadECC
bool enableSwap
uint32_t Region0BaseAddress
uint32_t Region0EndAddress
uint32_t Region1BaseAddress
uint32_t Region1EndAddress
uint32_t Region2BaseAddress
uint32_t Region2EndAddress
uint32_t Region3BaseAddress
uint32_t Region3EndAddress
Field Documentation
◆ enableReadECC
bool _xecc_config::enableReadECC
Enable read ECC function.
◆ enableSwap
bool _xecc_config::enableSwap
Enable swap function. The minimum ECC region range is 4k, so the lower 12 bits of this register must be 0.
◆ enableWriteECC
bool _xecc_config::enableWriteECC
Enable write ECC function.
◆ enableXECC
bool _xecc_config::enableXECC
Enable the XECC function.
◆ Region0BaseAddress
uint32_t _xecc_config::Region0BaseAddress
ECC region 0 base address.
◆ Region0EndAddress
uint32_t _xecc_config::Region0EndAddress
ECC region 0 end address.
◆ Region1BaseAddress
uint32_t _xecc_config::Region1BaseAddress
ECC region 1 base address.
◆ Region1EndAddress
uint32_t _xecc_config::Region1EndAddress
ECC region 1 end address.
◆ Region2BaseAddress
uint32_t _xecc_config::Region2BaseAddress
ECC region 2 base address.
◆ Region2EndAddress
uint32_t _xecc_config::Region2EndAddress
ECC region 2 end address.
◆ Region3BaseAddress
uint32_t _xecc_config::Region3BaseAddress
ECC region 3 base address.
◆ Region3EndAddress
uint32_t _xecc_config::Region3EndAddress
ECC region 3 end address.
