RTEMS 6.1-rc2
_sai_handle Struct Reference
SAI handle structure. More...
#include <fsl_sai.h>
I2S_Typebase
uint32_t state
sai_transfer_callback_t callback
void * userData
uint8_t bitWidth
uint8_t channel
uint8_t channelMask
uint8_t endChannel
uint8_t channelNums
sai_transfer_t saiQueue [SAI_XFER_QUEUE_SIZE]
size_t transferSize [SAI_XFER_QUEUE_SIZE]
volatile uint8_t queueUser
volatile uint8_t queueDriver
Field Documentation
◆ base
I2S_Type* _sai_handle::base
base address
◆ bitWidth
uint8_t _sai_handle::bitWidth
Bit width for transfer, 8/16/24/32 bits
◆ callback
sai_transfer_callback_t _sai_handle::callback
Callback function called at transfer event
◆ channel
uint8_t _sai_handle::channel
Transfer start channel
◆ channelMask
uint8_t _sai_handle::channelMask
enabled channel mask value, refernece _sai_channel_mask
◆ channelNums
uint8_t _sai_handle::channelNums
Total enabled channel numbers
◆ endChannel
uint8_t _sai_handle::endChannel
end channel number
◆ queueDriver
volatile uint8_t _sai_handle::queueDriver
Index for driver to get the transfer data and size
◆ queueUser
volatile uint8_t _sai_handle::queueUser
Index for user to queue transfer
◆ saiQueue
sai_transfer_t _sai_handle::saiQueue[SAI_XFER_QUEUE_SIZE]
Transfer queue storing queued transfer
◆ state
uint32_t _sai_handle::state
Transfer status
◆ transferSize
size_t _sai_handle::transferSize[SAI_XFER_QUEUE_SIZE]
Data bytes need to transfer
◆ userData
void* _sai_handle::userData
Callback parameter passed to callback function
