RTEMS 6.1-rc2
_rtems_rfs_inode Struct Reference
#include <rtems-rfs-inode.h>
uint16_t links
uint16_t mode
uint32_t owner
uint16_t flags
uint16_t block_offset
uint32_t block_count
rtems_rfs_time atime
rtems_rfs_time mtime
rtems_rfs_time ctime
union {
   rtems_rfs_inode_block   blocks [RTEMS_RFS_INODE_BLOCKS]
   uint8_t   name [RTEMS_RFS_INODE_DATA_NAME_SIZE]
data
rtems_rfs_inode_block last_map_block
rtems_rfs_inode_block last_data_block
The inode.
Field Documentation
◆ atime
rtems_rfs_time _rtems_rfs_inode::atime
The access time. The last time the file was read.
◆ block_count
uint32_t _rtems_rfs_inode::block_count
Number of blocks held by this file.
◆ block_offset
uint16_t _rtems_rfs_inode::block_offset
Amount of data held in the last block data.
◆ ctime
rtems_rfs_time _rtems_rfs_inode::ctime
The change time. The last time the inode was written too.
union { ... } _rtems_rfs_inode::data
Blocks. These are the block numbers used by the node or table of nodes. The flags indicate the mode the blocks are being held in. In the direct table mode the blocks are entries in this table. In the indirect mode the blocks point to blocks that hold the block numbers. The data can also be a name if it fits. For example a symbolic link.
◆ flags
uint16_t _rtems_rfs_inode::flags
Reserved.
◆ last_data_block
rtems_rfs_inode_block _rtems_rfs_inode::last_data_block
The last data block. Used as the goal when allocating a new block.
◆ last_map_block
rtems_rfs_inode_block _rtems_rfs_inode::last_map_block
The last block map block. Used as the goal when allocating a new block for use in the map.
◆ links
uint16_t _rtems_rfs_inode::links
The number of links to the inode.
◆ mode
uint16_t _rtems_rfs_inode::mode
The mode of the node.
◆ mtime
rtems_rfs_time _rtems_rfs_inode::mtime
The modified time. The last time the file was written too.
◆ owner
uint32_t _rtems_rfs_inode::owner
The owner of the node.
