RTEMS 6.1-rc2
_pdm_hwvad_config Struct Reference
PDM voice activity detector user configuration structure. More...
#include <fsl_pdm.h>
uint8_t channel
uint8_t initializeTime
uint8_t cicOverSampleRate
uint8_t inputGain
uint32_t frameTime
pdm_hwvad_hpf_config_t cutOffFreq
bool enableFrameEnergy
bool enablePreFilter
Field Documentation
◆ channel
uint8_t _pdm_hwvad_config::channel
Which channel uses voice activity detector
◆ cicOverSampleRate
uint8_t _pdm_hwvad_config::cicOverSampleRate
CIC filter over sampling rate
◆ cutOffFreq
pdm_hwvad_hpf_config_t _pdm_hwvad_config::cutOffFreq
High pass filter cut off frequency
◆ enableFrameEnergy
bool _pdm_hwvad_config::enableFrameEnergy
If frame energy enabled, true means enable
◆ enablePreFilter
bool _pdm_hwvad_config::enablePreFilter
If pre-filter enabled
◆ frameTime
uint32_t _pdm_hwvad_config::frameTime
Voice activity frame time
◆ initializeTime
uint8_t _pdm_hwvad_config::initializeTime
Number of frames or samples to initialize voice activity detector.
◆ inputGain
uint8_t _pdm_hwvad_config::inputGain
Voice activity detector input gain
