RTEMS 6.1-rc2
_lpi2c_master_config Struct Reference
Structure with settings to initialize the LPI2C master module. More...
#include <fsl_lpi2c.h>
bool enableMaster
bool enableDoze
bool debugEnable
bool ignoreAck
lpi2c_master_pin_config_t pinConfig
uint32_t baudRate_Hz
uint32_t busIdleTimeout_ns
uint32_t pinLowTimeout_ns
uint8_t sdaGlitchFilterWidth_ns
uint8_t sclGlitchFilterWidth_ns
struct {
   bool   _lpi2c_master_config::enable
   lpi2c_host_request_source_t   _lpi2c_master_config::source
   lpi2c_host_request_polarity_t   _lpi2c_master_config::polarity
hostRequest
This structure holds configuration settings for the LPI2C peripheral. To initialize this structure to reasonable defaults, call the LPI2C_MasterGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
