RTEMS 6.1-rc2
_flexio_i2s_config Struct Reference
FlexIO I2S configure structure. More...
#include <fsl_flexio_i2s.h>
bool enableI2S
flexio_i2s_master_slave_t masterSlave
flexio_pin_polarity_t txPinPolarity
flexio_pin_polarity_t rxPinPolarity
flexio_pin_polarity_t bclkPinPolarity
flexio_pin_polarity_t fsPinPolarity
flexio_shifter_timer_polarity_t txTimerPolarity
flexio_shifter_timer_polarity_t rxTimerPolarity
Field Documentation
◆ bclkPinPolarity
flexio_pin_polarity_t _flexio_i2s_config::bclkPinPolarity
Bit clock pin polarity
◆ enableI2S
bool _flexio_i2s_config::enableI2S
Enable FlexIO I2S
◆ fsPinPolarity
flexio_pin_polarity_t _flexio_i2s_config::fsPinPolarity
Frame sync pin polarity
◆ masterSlave
flexio_i2s_master_slave_t _flexio_i2s_config::masterSlave
Master or slave
◆ rxPinPolarity
flexio_pin_polarity_t _flexio_i2s_config::rxPinPolarity
Rx data pin polarity
◆ rxTimerPolarity
flexio_shifter_timer_polarity_t _flexio_i2s_config::rxTimerPolarity
Rx data valid on bclk rising or falling edge
◆ txPinPolarity
flexio_pin_polarity_t _flexio_i2s_config::txPinPolarity
Tx data pin polarity, active high or low
◆ txTimerPolarity
flexio_shifter_timer_polarity_t _flexio_i2s_config::txTimerPolarity
Tx data valid on bclk rising or falling edge
