RTEMS 6.1-rc2
Configuration for the loop control. More...
#include <fsl_dcdc.h>
Data Fields | |
bool | enableCommonHysteresis |
bool | enableCommonThresholdDetection |
bool | enableDifferentialHysteresis |
bool | enableDifferentialThresholdDetection |
bool | enableInvertHysteresisSign |
bool | enableRCThresholdDetection |
uint32_t | enableRCScaleCircuit |
uint32_t | complementFeedForwardStep |
uint32_t | controlParameterMagnitude |
uint32_t | integralProportionalRatio |
uint32_t _dcdc_loop_control_config::controlParameterMagnitude |
Available range is 0~15. Magnitude of proportional control parameter in the switching DC-DC converter control loop.
bool _dcdc_loop_control_config::enableDifferentialHysteresis |
Enable hysteresis in switching converter differential mode analog comparators. This feature will improve transient supply ripple and efficiency.
bool _dcdc_loop_control_config::enableDifferentialThresholdDetection |
Increase the threshold detection for differential mode analog comparators.
uint32_t _dcdc_loop_control_config::integralProportionalRatio |
Available range is 0~3.Ratio of integral control parameter to proportional control parameter in the switching DC-DC converter, and can be used to optimize efficiency and loop response.
