RTEMS 6.1-rc2
_FlexSPIConfig Struct Reference
FlexSPI Memory Configuration Block. More...
#include <fsl_flexspi_nor_config.h>
uint32_t tag
 [0x000-0x003] Tag, fixed value 0x42464346UL
uint32_t version
 [0x004-0x007] Version,[31:24] -'V', [23:16] - Major, [15:8] - Minor, [7:0] - bugfix
uint32_t reserved0
 [0x008-0x00b] Reserved for future use
uint8_t readSampleClkSrc
 [0x00c-0x00c] Read Sample Clock Source, valid value: 0/1/3
uint8_t csHoldTime
 [0x00d-0x00d] CS hold time, default value: 3
uint8_t csSetupTime
 [0x00e-0x00e] CS setup time, default value: 3
uint8_t columnAddressWidth
uint8_t deviceModeCfgEnable
 Serial NAND, need to refer to datasheet.
uint8_t deviceModeType
uint16_t waitTimeCfgCommands
 Generic configuration, etc.
flexspi_lut_seq_t deviceModeSeq
 DPI/QPI/OPI switch or reset command.
uint32_t deviceModeArg
 sequence number, [31:16] Reserved
uint8_t configCmdEnable
 [0x01c-0x01c] Configure command Enable Flag, 1 - Enable, 0 - Disable
uint8_t configModeType [3]
 [0x01d-0x01f] Configure Mode Type, similar as deviceModeTpe
flexspi_lut_seq_t configCmdSeqs [3]
 [0x020-0x02b] Sequence info for Device Configuration command, similar as deviceModeSeq
uint32_t reserved1
 [0x02c-0x02f] Reserved for future use
uint32_t configCmdArgs [3]
 [0x030-0x03b] Arguments/Parameters for device Configuration commands
uint32_t reserved2
 [0x03c-0x03f] Reserved for future use
uint32_t controllerMiscOption
uint8_t deviceType
 details
uint8_t sflashPadType
 [0x045-0x045] Serial Flash Pad Type: 1 - Single, 2 - Dual, 4 - Quad, 8 - Octal
uint8_t serialClkFreq
uint8_t lutCustomSeqEnable
 Chapter for more details.
uint32_t reserved3 [2]
 be done using 1 LUT sequence, currently, only applicable to HyperFLASH
uint32_t sflashA1Size
 [0x050-0x053] Size of Flash connected to A1
uint32_t sflashA2Size
 [0x054-0x057] Size of Flash connected to A2
uint32_t sflashB1Size
 [0x058-0x05b] Size of Flash connected to B1
uint32_t sflashB2Size
 [0x05c-0x05f] Size of Flash connected to B2
uint32_t csPadSettingOverride
 [0x060-0x063] CS pad setting override value
uint32_t sclkPadSettingOverride
 [0x064-0x067] SCK pad setting override value
uint32_t dataPadSettingOverride
 [0x068-0x06b] data pad setting override value
uint32_t dqsPadSettingOverride
 [0x06c-0x06f] DQS pad setting override value
uint32_t timeoutInMs
 [0x070-0x073] Timeout threshold for read status command
uint32_t commandInterval
 [0x074-0x077] CS deselect interval between two commands
uint16_t dataValidTime [2]
 [0x078-0x07b] CLK edge to data valid time for PORT A and PORT B, in terms of 0.1ns
uint16_t busyOffset
 [0x07c-0x07d] Busy offset, valid value: 0-31
uint16_t busyBitPolarity
uint32_t lookupTable [64]
 busy flag is 0 when flash device is busy
flexspi_lut_seq_t lutCustomSeq [12]
 [0x180-0x1af] Customizable LUT Sequences
uint32_t reserved4 [4]
 [0x1b0-0x1bf] Reserved for future use
Field Documentation
◆ busyBitPolarity
uint16_t _FlexSPIConfig::busyBitPolarity
[0x07e-0x07f] Busy flag polarity, 0 - busy flag is 1 when flash device is busy, 1 -
◆ columnAddressWidth
uint8_t _FlexSPIConfig::columnAddressWidth
[0x00f-0x00f] Column Address with, for HyperBus protocol, it is fixed to 3, For
◆ controllerMiscOption
uint32_t _FlexSPIConfig::controllerMiscOption
[0x040-0x043] Controller Misc Options, see Misc feature bit definitions for more
◆ deviceModeArg
uint32_t _FlexSPIConfig::deviceModeArg
[0x018-0x01b] Argument/Parameter for device configuration
◆ deviceModeCfgEnable
uint8_t _FlexSPIConfig::deviceModeCfgEnable
[0x010-0x010] Device Mode Configure enable flag, 1 - Enable, 0 - Disable
◆ deviceModeSeq
flexspi_lut_seq_t _FlexSPIConfig::deviceModeSeq
[0x014-0x017] Device mode sequence info, [7:0] - LUT sequence id, [15:8] - LUt
◆ deviceModeType
uint8_t _FlexSPIConfig::deviceModeType
[0x011-0x011] Specify the configuration command type:Quad Enable, DPI/QPI/OPI switch,
◆ deviceType
uint8_t _FlexSPIConfig::deviceType
details
[0x044-0x044] Device Type: See Flash Type Definition for more details
◆ lookupTable
uint32_t _FlexSPIConfig::lookupTable[64]
[0x080-0x17f] Lookup table holds Flash command sequences
◆ lutCustomSeqEnable
uint8_t _FlexSPIConfig::lutCustomSeqEnable
[0x047-0x047] LUT customization Enable, it is required if the program/erase cannot
◆ reserved3
uint32_t _FlexSPIConfig::reserved3[2]
[0x048-0x04f] Reserved for future use
◆ serialClkFreq
uint8_t _FlexSPIConfig::serialClkFreq
[0x046-0x046] Serial Flash Frequencey, device specific definitions, See System Boot
◆ waitTimeCfgCommands
uint16_t _FlexSPIConfig::waitTimeCfgCommands
[0x012-0x013] Wait time for all configuration commands, unit: 100us, Used for
