RTEMS 6.1-rc2
Test context for spec:/score/tq/req/timeout-mrsp test case. More...
bool other_scheduler
 If this member is true, then the enqueued thread shall use a home scheduler other than the home scheduler of the owner.
bool restore_scheduler
 If this member is true, then the processor set of the schedulers shall be restored.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqTimeoutMrsp_Run() parameter.
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqTimeoutMrsp_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
