RTEMS 6.1-rc2
Test context for spec:/score/tq/req/flush-fifo test case. More...
bool stop
 If this member is true, then the flush filter shall return NULL.
bool intend_to_block
 If this member is true, then the least recently enqueued thread shall be in the intend to block wait state.
CallWithinISRRequest request
 This member contains the call within ISR request.
TQContexttq_ctx
 This member contains a copy of the corresponding ScoreTqReqFlushFifo_Run() parameter.
bool may_stop
struct {
   size_t   pci [4]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   ScoreTqReqFlushFifo_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
