RTEMS 6.1-rc2
Test context for spec:/score/sched/req/yield test case. More...
Data Fields | |
TQContext | tq_ctx |
This member contains the thread queue test context. | |
rtems_id | sticky_mutex |
This member contains the identifier of a sticky mutex. | |
uint32_t | cpu_after_yield |
This member contains the processor index after yielding. | |
bool | has_helping |
If this member is true, then the runner shall have a helping scheduler. | |
bool | use_helping |
If this member is true, then the runner shall use a helping scheduler. | |
bool | ready |
If this member is true, then the runner shall be ready in its home scheduler. | |
bool | sticky |
If this member is true, then the runner shall be sticky. | |
bool | other_ready |
If this member is true, then another ready task in the home scheduler of the runner shall be ready with an equal priority. | |
bool | is_idle_before_yield |
If this member is true, then the processor zero was idle before yielding. | |
bool | is_idle_after_yield |
If this member is true, then the processor zero was idle after yielding. | |
struct { | |
size_t pcs [5] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
ScoreSchedReqYield_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
