RTEMS 6.1-rc2
Test context for spec:/rtems/timer/req/create test case. More...
Data Fields | |
void * | seized_objects |
This member is used by the T_seize_objects() and T_surrender_objects() support functions. | |
rtems_id | id_value |
This member may contain the object identifier returned by rtems_timer_create(). | |
rtems_name | name |
This member specifies the name parameter for the action. | |
rtems_id * | id |
This member specifies the id parameter for the action. | |
rtems_status_code | status |
This member contains the return status of the action. | |
struct { | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTimerReqCreate_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
