RTEMS 6.1-rc2
Test context for spec:/rtems/task/req/set-priority test case. More...
Data Fields | |
rtems_id | worker_id |
This member contains the worker task identifier. | |
bool | started |
If this member is true, then the task shall be started. | |
bool | blocked |
If this member is true, then the task shall be blocked. | |
rtems_task_priority | old_priority_obj |
This member provides the object referenced by the old_priority parameter. | |
rtems_status_code | status |
This member contains the return value of the rtems_task_set_priority() call. | |
rtems_id | id |
This member specifies if the id parameter value. | |
rtems_task_priority | new_priority |
This member specifies if the new_priority parameter value. | |
rtems_task_priority * | old_priority |
This member specifies if the old_priority parameter value. | |
struct { | |
size_t pci [5] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [5] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTaskReqSetPriority_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
