RTEMS 6.1-rc2
Test context for spec:/rtems/task/req/exit test case. More...
T_scheduler_log_4 scheduler_log
 This member provides the scheduler operation records.
rtems_id runner_id
 This member contains the identifier of the runner task.
rtems_id worker_id
 This member contains the identifier of the worker task.
rtems_id deleter_id
 This member contains the identifier of the deleter task.
rtems_id extension_id
 This member contains the identifier of the test user extensions.
uint32_t fatal_extension_calls
 This member contains the count of fatal extension calls.
uint32_t delete_extension_calls
 This member contains the count of thread delete extension calls.
uint32_t restart_extension_calls
 This member contains the count of thread restart extension calls.
uint32_t terminate_extension_calls
 This member contains the count of thread terminate extension calls.
bool protected
 If this member is true, then the thread life of the worker is protected before the rtems_task_exit() call.
bool allocator_locked
 If this member is true, then the worker locked the allocator.
bool restarting
 If this member is true, then the worker is restarting before the rtems_task_exit() call.
bool terminating
 If this member is true, then the worker is terminating before the rtems_task_exit() call.
bool dispatch_disabled
 If this member is true, then thread dispatching is disabled by the worker task before the rtems_task_exit() call.
bool delete_worker_expected
 If this member is true, then it is expected to delete the worker.
struct {
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqExit_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
