RTEMS 6.1-rc2
Test context for spec:/rtems/signal/req/send test case. More...
rtems_id runner_id
rtems_id worker_id
rtems_asr_entry handler
size_t nested
size_t handler_calls
size_t calls_after_send
size_t calls_after_dispatch
size_t calls_after_enable
rtems_signal_set processed_signal_sets [2]
uintptr_t stack_pointers [2]
rtems_mode mode
rtems_status_code status
rtems_id id
rtems_signal_set signal_set
struct {
   size_t   pcs [5]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSignalReqSend_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
