RTEMS 6.1-rc2
Test context for spec:/rtems/sem/req/flush test case. More...
Data Fields | |
TQContext | tq_ctx |
This member contains the thread queue test context. | |
rtems_attribute | attribute_set |
This member specifies if the attribute set of the semaphore. | |
uint32_t | initial_count |
This member specifies if the initial count of the semaphore. | |
struct { | |
size_t pci [3] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [3] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsSemReqFlush_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
