RTEMS 6.1-rc2
Test context for spec:/rtems/scheduler/req/ident test case. More...
rtems_id id_value
 This member provides the object referenced by the id parameter.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_ident() call.
rtems_name name
 This member specifies if the name parameter value.
rtems_idid
 This member specifies if the id parameter value.
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSchedulerReqIdent_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
