RTEMS 6.1-rc2
Test context for spec:/rtems/scheduler/req/add-processor test case. More...
rtems_id scheduler_id
 This member specifies the scheduler used to add the processor.
rtems_id scheduler_a_id
 This member contains the identifier of scheduler A.
rtems_id scheduler_b_id
 This member contains the identifier of scheduler B.
rtems_id scheduler_c_id
 This member contains the identifier of scheduler C.
Per_CPU_Controlcpu
 This member references the processor control of the processor to add.
bool online
 This member contains the online status of the processor to add before the rtems_scheduler_add_processor() call is prepared.
bool add_cpu_to_scheduler_b
 If this member is true, then the processor should be added to the scheduler B during cleanup.
T_scheduler_log_2 scheduler_log
 This member provides the scheduler operation records.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_add_processor() call.
rtems_id id
 This member specifies if the scheduler_id parameter value.
uint32_t cpu_index
 This member specifies if the cpu_index parameter value.
struct {
   size_t   pci [4]
 This member defines the pre-condition indices for the next action.
   size_t   pcs [4]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSchedulerReqAddProcessor_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
