RTEMS 6.1-rc2
Test context for spec:/rtems/message/req/delete test case. More...
Data Fields | |
rtems_id | worker_id |
rtems_id | message_queue_id |
uint32_t | wait_done |
uint32_t | wait_expected |
rtems_id | id |
rtems_status_code | status |
struct { | |
size_t pcs [1] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsMessageReqDelete_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
