RTEMS 6.1-rc2
Test context for spec:/rtems/message/req/broadcast test case. More...
Data Fields | |
rtems_id | message_queue_id |
This member contains a valid ID of a message queue. | |
storage_area [MAXIMUM_PENDING_MESSAGES] | |
This member is used as storage area for the message queue. | |
uint8_t | receive_buffer [NUMBER_OF_WORKERS][MAXIMUM_MESSAGE_SIZE] |
This member contains a buffer to receive messages from the queue. | |
size_t | receive_size [NUMBER_OF_WORKERS] |
This member contains several buffers to receive a messages size. | |
rtems_status_code | receive_status [NUMBER_OF_WORKERS] |
This member contains the returned status codes of the receivers. | |
rtems_id | id_param |
This member specifies the id parameter of the action. | |
const void * | buffer_param |
This member specifies the buffer parameter of the action. | |
size_t | size_param |
This member specifies the size parameter of the action. | |
uint32_t * | count_param |
This member specifies the count parameter of the action. | |
rtems_status_code | status |
This member contains the returned status code of the action. | |
uint32_t | count |
This member contains the value returned in parameter count of the action. | |
rtems_id | worker_id [NUMBER_OF_WORKERS] |
This member contains the task identifiers of the worker tasks. | |
void(* | check_msgq_unchanged )(void *ctx_in) |
This member contains a pointer to a function which is executed to check that the action has not changed the content of the message queue. | |
struct { | |
size_t pcs [7] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsMessageReqBroadcast_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
