RTEMS 6.1-rc2
Test context for spec:/rtems/io/req/putc test case. More...
Data Fields | |
int | output [2] |
This member contains the character output. | |
size_t | output_count |
This member contains the character output count. | |
char | character |
This member specifies if the c parameter value. | |
struct { | |
size_t pcs [1] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsIoReqPutc_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
