RTEMS 6.1-rc2
Test context for spec:/rtems/io/req/getchark test case. More...
size_t input_count
 This member contains the character input count.
BSP_polling_getchar_function_type poll_char
 This member specifies the value for BSP_poll_char.
int result
 This member contains the return value of the getchark() call.
struct {
   size_t   pcs [1]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIoReqGetchark_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
