RTEMS 6.1-rc2
Test context for spec:/rtems/clock/req/get-tod test case. More...
rtems_status_code set_tod_status
rtems_time_of_day set_tod_value
rtems_time_of_dayget_tod_ref
rtems_time_of_day get_tod_value
rtems_status_code get_tod_status
bool isDef
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsClockReqGetTod_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
