RTEMS 6.1-rc2
Test context for spec:/dev/grlib/req/apbuart-inbyte-nonblocking test case. More...
Data Fields | |
apbuart | regs |
This member provides the APBUART register block. | |
int | result |
This member contains the return value of the apbuart_inbyte_nonblocking() call. | |
struct { | |
size_t pcs [1] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
DevGrlibReqApbuartInbyteNonblocking_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
