RTEMS 6.1-rc2
Macros | Functions
stm32h7xx_ll_swpmi.h File Reference
Header file of SWPMI LL module. More...
#include "stm32h7xx.h"
#define LL_SWPMI_ICR_CRXBFF   SWPMI_ICR_CRXBFF
#define LL_SWPMI_ICR_CTXBEF   SWPMI_ICR_CTXBEF
#define LL_SWPMI_ICR_CRXBERF   SWPMI_ICR_CRXBERF
#define LL_SWPMI_ICR_CRXOVRF   SWPMI_ICR_CRXOVRF
#define LL_SWPMI_ICR_CTXUNRF   SWPMI_ICR_CTXUNRF
#define LL_SWPMI_ICR_CTCF   SWPMI_ICR_CTCF
#define LL_SWPMI_ICR_CSRF   SWPMI_ICR_CSRF
#define LL_SWPMI_ISR_RXBFF   SWPMI_ISR_RXBFF
#define LL_SWPMI_ISR_TXBEF   SWPMI_ISR_TXBEF
#define LL_SWPMI_ISR_RXBERF   SWPMI_ISR_RXBERF
#define LL_SWPMI_ISR_RXOVRF   SWPMI_ISR_RXOVRF
#define LL_SWPMI_ISR_TXUNRF   SWPMI_ISR_TXUNRF
#define LL_SWPMI_ISR_RXNE   SWPMI_ISR_RXNE
#define LL_SWPMI_ISR_TXE   SWPMI_ISR_TXE
#define LL_SWPMI_ISR_TCF   SWPMI_ISR_TCF
#define LL_SWPMI_ISR_SRF   SWPMI_ISR_SRF
#define LL_SWPMI_ISR_SUSP   SWPMI_ISR_SUSP
#define LL_SWPMI_ISR_DEACTF   SWPMI_ISR_DEACTF
#define LL_SWPMI_IER_SRIE   SWPMI_IER_SRIE
#define LL_SWPMI_IER_TCIE   SWPMI_IER_TCIE
#define LL_SWPMI_IER_TIE   SWPMI_IER_TIE
#define LL_SWPMI_IER_RIE   SWPMI_IER_RIE
#define LL_SWPMI_IER_TXUNRIE   SWPMI_IER_TXUNRIE
#define LL_SWPMI_IER_RXOVRIE   SWPMI_IER_RXOVRIE
#define LL_SWPMI_IER_RXBERIE   SWPMI_IER_RXBERIE
#define LL_SWPMI_IER_TXBEIE   SWPMI_IER_TXBEIE
#define LL_SWPMI_IER_RXBFIE   SWPMI_IER_RXBFIE
#define LL_SWPMI_SW_BUFFER_RX_SINGLE   ((uint32_t)0x00000000)
#define LL_SWPMI_SW_BUFFER_RX_MULTI   SWPMI_CR_RXMODE
#define LL_SWPMI_SW_BUFFER_TX_SINGLE   ((uint32_t)0x00000000)
#define LL_SWPMI_SW_BUFFER_TX_MULTI   SWPMI_CR_TXMODE
#define LL_SWPMI_VOLTAGE_CLASS_C   ((uint32_t)0x00000000)
#define LL_SWPMI_VOLTAGE_CLASS_B   SWPMI_OR_CLASS
#define LL_SWPMI_DMA_REG_DATA_TRANSMIT   (uint32_t)0
#define LL_SWPMI_DMA_REG_DATA_RECEIVE   (uint32_t)1
#define LL_SWPMI_WriteReg(__INSTANCE__, __REG__, __VALUE__)   WRITE_REG(__INSTANCE__->__REG__, (__VALUE__))
 Write a value in SWPMI register.
#define LL_SWPMI_ReadReg(__INSTANCE__, __REG__)   READ_REG(__INSTANCE__->__REG__)
 Read a value in SWPMI register.
#define __LL_SWPMI_CALC_BITRATE_PRESCALER(__FSWP__, __FSWPCLK__)   ((uint32_t)(((__FSWPCLK__) / ((__FSWP__) * 4)) - 1))
 Helper macro to calculate bit rate value to set in BRR register (LL_SWPMI_SetBitRatePrescaler function)
__STATIC_INLINE void LL_SWPMI_SetReceptionMode (SWPMI_TypeDef *SWPMIx, uint32_t RxBufferingMode)
 Set Reception buffering mode.
__STATIC_INLINE uint32_t LL_SWPMI_GetReceptionMode (SWPMI_TypeDef *SWPMIx)
 Get Reception buffering mode @rmtoll CR RXMODE LL_SWPMI_GetReceptionMode.
__STATIC_INLINE void LL_SWPMI_SetTransmissionMode (SWPMI_TypeDef *SWPMIx, uint32_t TxBufferingMode)
 Set Transmission buffering mode.
__STATIC_INLINE uint32_t LL_SWPMI_GetTransmissionMode (SWPMI_TypeDef *SWPMIx)
 Get Transmission buffering mode @rmtoll CR TXMODE LL_SWPMI_GetTransmissionMode.
__STATIC_INLINE void LL_SWPMI_EnableLoopback (SWPMI_TypeDef *SWPMIx)
 Enable loopback mode @rmtoll CR LPBK LL_SWPMI_EnableLoopback.
__STATIC_INLINE void LL_SWPMI_DisableLoopback (SWPMI_TypeDef *SWPMIx)
 Disable loopback mode @rmtoll CR LPBK LL_SWPMI_DisableLoopback.
__STATIC_INLINE void LL_SWPMI_EnableTransceiver (SWPMI_TypeDef *SWPMIx)
 Enable SWPMI transceiver.
__STATIC_INLINE void LL_SWPMI_DisableTransceiver (SWPMI_TypeDef *SWPMIx)
 Disable SWPMI transceiver.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledTransceiver (SWPMI_TypeDef *SWPMIx)
 Check if SWPMI transceiver is enabled @rmtoll CR SWPEN LL_SWPMI_IsEnabledTransceiver.
__STATIC_INLINE void LL_SWPMI_Activate (SWPMI_TypeDef *SWPMIx)
 Activate Single wire protocol bus (SUSPENDED or ACTIVATED state)
__STATIC_INLINE uint32_t LL_SWPMI_IsActivated (SWPMI_TypeDef *SWPMIx)
 Check if Single wire protocol bus is in ACTIVATED state. @rmtoll CR SWPACT LL_SWPMI_Activate.
__STATIC_INLINE void LL_SWPMI_Deactivate (SWPMI_TypeDef *SWPMIx)
 Deactivate immediately Single wire protocol bus (immediate transition to DEACTIVATED state) @rmtoll CR SWPACT LL_SWPMI_Deactivate.
__STATIC_INLINE void LL_SWPMI_RequestDeactivation (SWPMI_TypeDef *SWPMIx)
 Request a deactivation of Single wire protocol bus (request to go in DEACTIVATED state if no resume from slave) @rmtoll CR DEACT LL_SWPMI_RequestDeactivation.
__STATIC_INLINE void LL_SWPMI_SetBitRatePrescaler (SWPMI_TypeDef *SWPMIx, uint32_t BitRatePrescaler)
 Set Bitrate prescaler SWPMI_freq = SWPMI_clk / (((BitRate) + 1) * 4) @rmtoll BRR BR LL_SWPMI_SetBitRatePrescaler.
__STATIC_INLINE uint32_t LL_SWPMI_GetBitRatePrescaler (SWPMI_TypeDef *SWPMIx)
 Get Bitrate prescaler @rmtoll BRR BR LL_SWPMI_GetBitRatePrescaler.
__STATIC_INLINE void LL_SWPMI_SetVoltageClass (SWPMI_TypeDef *SWPMIx, uint32_t VoltageClass)
 Set SWP Voltage Class @rmtoll OR CLASS LL_SWPMI_SetVoltageClass.
__STATIC_INLINE uint32_t LL_SWPMI_GetVoltageClass (SWPMI_TypeDef *SWPMIx)
 Get SWP Voltage Class @rmtoll OR CLASS LL_SWPMI_GetVoltageClass.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBF (SWPMI_TypeDef *SWPMIx)
 Check if the last word of the frame under reception has arrived in SWPMI_RDR. @rmtoll ISR RXBFF LL_SWPMI_IsActiveFlag_RXBF.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXBE (SWPMI_TypeDef *SWPMIx)
 Check if Frame transmission buffer has been emptied @rmtoll ISR TXBEF LL_SWPMI_IsActiveFlag_TXBE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBER (SWPMI_TypeDef *SWPMIx)
 Check if CRC error in reception has been detected @rmtoll ISR RXBERF LL_SWPMI_IsActiveFlag_RXBER.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXOVR (SWPMI_TypeDef *SWPMIx)
 Check if Overrun in reception has been detected @rmtoll ISR RXOVRF LL_SWPMI_IsActiveFlag_RXOVR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXUNR (SWPMI_TypeDef *SWPMIx)
 Check if underrun error in transmission has been detected @rmtoll ISR TXUNRF LL_SWPMI_IsActiveFlag_TXUNR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXNE (SWPMI_TypeDef *SWPMIx)
 Check if Receive data register not empty (it means that Received data is ready to be read in the SWPMI_RDR register) @rmtoll ISR RXNE LL_SWPMI_IsActiveFlag_RXNE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXE (SWPMI_TypeDef *SWPMIx)
 Check if Transmit data register is empty (it means that Data written in transmit data register SWPMI_TDR has been transmitted and SWPMI_TDR can be written to again) @rmtoll ISR TXE LL_SWPMI_IsActiveFlag_TXE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TC (SWPMI_TypeDef *SWPMIx)
 Check if Both transmission and reception are completed and SWP is switched to the SUSPENDED state @rmtoll ISR TCF LL_SWPMI_IsActiveFlag_TC.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SR (SWPMI_TypeDef *SWPMIx)
 Check if a Resume by slave state has been detected during the SWP bus SUSPENDED state @rmtoll ISR SRF LL_SWPMI_IsActiveFlag_SR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SUSP (SWPMI_TypeDef *SWPMIx)
 Check if SWP bus is in SUSPENDED or DEACTIVATED state @rmtoll ISR SUSP LL_SWPMI_IsActiveFlag_SUSP.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_DEACT (SWPMI_TypeDef *SWPMIx)
 Check if SWP bus is in DEACTIVATED state @rmtoll ISR DEACTF LL_SWPMI_IsActiveFlag_DEACT.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RDYF (SWPMI_TypeDef *SWPMIx)
 Check if SWPMI transceiver is ready @rmtoll ISR RDYF LL_SWPMI_IsActiveFlag_RDYF.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBF (SWPMI_TypeDef *SWPMIx)
 Clear receive buffer full flag @rmtoll ICR CRXBFF LL_SWPMI_ClearFlag_RXBF.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXBE (SWPMI_TypeDef *SWPMIx)
 Clear transmit buffer empty flag @rmtoll ICR CTXBEF LL_SWPMI_ClearFlag_TXBE.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBER (SWPMI_TypeDef *SWPMIx)
 Clear receive CRC error flag @rmtoll ICR CRXBERF LL_SWPMI_ClearFlag_RXBER.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXOVR (SWPMI_TypeDef *SWPMIx)
 Clear receive overrun error flag @rmtoll ICR CRXOVRF LL_SWPMI_ClearFlag_RXOVR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXUNR (SWPMI_TypeDef *SWPMIx)
 Clear transmit underrun error flag @rmtoll ICR CTXUNRF LL_SWPMI_ClearFlag_TXUNR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TC (SWPMI_TypeDef *SWPMIx)
 Clear transfer complete flag @rmtoll ICR CTCF LL_SWPMI_ClearFlag_TC.
__STATIC_INLINE void LL_SWPMI_ClearFlag_SR (SWPMI_TypeDef *SWPMIx)
 Clear slave resume flag @rmtoll ICR CSRF LL_SWPMI_ClearFlag_SR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RDY (SWPMI_TypeDef *SWPMIx)
 Clear SWPMI transceiver ready flag @rmtoll ISR CRDYF LL_SWPMI_ClearFlag_RDY.
__STATIC_INLINE void LL_SWPMI_EnableIT_RDY (SWPMI_TypeDef *SWPMIx)
 Enable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_EnableIT_RDY.
__STATIC_INLINE void LL_SWPMI_EnableIT_SR (SWPMI_TypeDef *SWPMIx)
 Enable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_EnableIT_SR.
__STATIC_INLINE void LL_SWPMI_EnableIT_TC (SWPMI_TypeDef *SWPMIx)
 Enable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_EnableIT_TC.
__STATIC_INLINE void LL_SWPMI_EnableIT_TX (SWPMI_TypeDef *SWPMIx)
 Enable Transmit interrupt @rmtoll IER TIE LL_SWPMI_EnableIT_TX.
__STATIC_INLINE void LL_SWPMI_EnableIT_RX (SWPMI_TypeDef *SWPMIx)
 Enable Receive interrupt @rmtoll IER RIE LL_SWPMI_EnableIT_RX.
__STATIC_INLINE void LL_SWPMI_EnableIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Enable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_EnableIT_TXUNR.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Enable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_EnableIT_RXOVR.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Enable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_EnableIT_RXBER.
__STATIC_INLINE void LL_SWPMI_EnableIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Enable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_EnableIT_TXBE.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Enable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_EnableIT_RXBF.
__STATIC_INLINE void LL_SWPMI_DisableIT_RDY (SWPMI_TypeDef *SWPMIx)
 Disable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_DisableIT_RDY.
__STATIC_INLINE void LL_SWPMI_DisableIT_SR (SWPMI_TypeDef *SWPMIx)
 Disable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_DisableIT_SR.
__STATIC_INLINE void LL_SWPMI_DisableIT_TC (SWPMI_TypeDef *SWPMIx)
 Disable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_DisableIT_TC.
__STATIC_INLINE void LL_SWPMI_DisableIT_TX (SWPMI_TypeDef *SWPMIx)
 Disable Transmit interrupt @rmtoll IER TIE LL_SWPMI_DisableIT_TX.
__STATIC_INLINE void LL_SWPMI_DisableIT_RX (SWPMI_TypeDef *SWPMIx)
 Disable Receive interrupt @rmtoll IER RIE LL_SWPMI_DisableIT_RX.
__STATIC_INLINE void LL_SWPMI_DisableIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Disable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_DisableIT_TXUNR.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Disable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_DisableIT_RXOVR.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Disable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_DisableIT_RXBER.
__STATIC_INLINE void LL_SWPMI_DisableIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Disable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_DisableIT_TXBE.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Disable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_DisableIT_RXBF.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RDY (SWPMI_TypeDef *SWPMIx)
 Check if SWPMI transceiver ready interrupt is enabled @rmtoll IER RDYIE LL_SWPMI_IsEnabledIT_RDY.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_SR (SWPMI_TypeDef *SWPMIx)
 Check if Slave resume interrupt is enabled @rmtoll IER SRIE LL_SWPMI_IsEnabledIT_SR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TC (SWPMI_TypeDef *SWPMIx)
 Check if Transmit complete interrupt is enabled @rmtoll IER TCIE LL_SWPMI_IsEnabledIT_TC.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TX (SWPMI_TypeDef *SWPMIx)
 Check if Transmit interrupt is enabled @rmtoll IER TIE LL_SWPMI_IsEnabledIT_TX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RX (SWPMI_TypeDef *SWPMIx)
 Check if Receive interrupt is enabled @rmtoll IER RIE LL_SWPMI_IsEnabledIT_RX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Check if Transmit underrun error interrupt is enabled @rmtoll IER TXUNRIE LL_SWPMI_IsEnabledIT_TXUNR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Check if Receive overrun error interrupt is enabled @rmtoll IER RXOVRIE LL_SWPMI_IsEnabledIT_RXOVR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Check if Receive CRC error interrupt is enabled @rmtoll IER RXBERIE LL_SWPMI_IsEnabledIT_RXBER.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Check if Transmit buffer empty interrupt is enabled @rmtoll IER TXBEIE LL_SWPMI_IsEnabledIT_TXBE.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Check if Receive buffer full interrupt is enabled @rmtoll IER RXBFIE LL_SWPMI_IsEnabledIT_RXBF.
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Enable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_EnableDMAReq_RX.
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Disable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_DisableDMAReq_RX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Check if DMA mode for reception is enabled @rmtoll CR RXDMA LL_SWPMI_IsEnabledDMAReq_RX.
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Enable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_EnableDMAReq_TX.
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Disable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_DisableDMAReq_TX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Check if DMA mode for transmission is enabled @rmtoll CR TXDMA LL_SWPMI_IsEnabledDMAReq_TX.
__STATIC_INLINE uint32_t LL_SWPMI_DMA_GetRegAddr (SWPMI_TypeDef *SWPMIx, uint32_t Direction)
 Get the data register address used for DMA transfer @rmtoll TDR TD LL_SWPMI_DMA_GetRegAddr
RDR RD LL_SWPMI_DMA_GetRegAddr.
__STATIC_INLINE uint32_t LL_SWPMI_GetReceiveFrameLength (SWPMI_TypeDef *SWPMIx)
 Retrieve number of data bytes present in payload of received frame @rmtoll RFL RFL LL_SWPMI_GetReceiveFrameLength.
__STATIC_INLINE void LL_SWPMI_TransmitData32 (SWPMI_TypeDef *SWPMIx, uint32_t TxData)
 Transmit Data Register @rmtoll TDR TD LL_SWPMI_TransmitData32.
__STATIC_INLINE uint32_t LL_SWPMI_ReceiveData32 (SWPMI_TypeDef *SWPMIx)
 Receive Data Register @rmtoll RDR RD LL_SWPMI_ReceiveData32.
__STATIC_INLINE void LL_SWPMI_EnableTXBypass (SWPMI_TypeDef *SWPMIx)
 Enable SWP Transceiver Bypass.
__STATIC_INLINE void LL_SWPMI_DisableTXBypass (SWPMI_TypeDef *SWPMIx)
 Disable SWP Transceiver Bypass.
Author
MCD Application Team
Attention
