RTEMS 6.1-rc2
Header file of USART HAL module. More...
struct | USART_InitTypeDef |
USART Init Structure definition. More... | |
struct | __USART_HandleTypeDef |
USART handle Structure definition. More... | |
#define | HAL_USART_ERROR_NONE (0x00000000U) |
#define | HAL_USART_ERROR_PE (0x00000001U) |
#define | HAL_USART_ERROR_NE (0x00000002U) |
#define | HAL_USART_ERROR_FE (0x00000004U) |
#define | HAL_USART_ERROR_ORE (0x00000008U) |
#define | HAL_USART_ERROR_DMA (0x00000010U) |
#define | HAL_USART_ERROR_UDR (0x00000020U) |
#define | HAL_USART_ERROR_RTO (0x00000080U) |
#define | USART_STOPBITS_0_5 USART_CR2_STOP_0 |
#define | USART_STOPBITS_1 0x00000000U |
#define | USART_STOPBITS_1_5 (USART_CR2_STOP_0 | USART_CR2_STOP_1) |
#define | USART_STOPBITS_2 USART_CR2_STOP_1 |
#define | USART_PARITY_NONE 0x00000000U |
#define | USART_PARITY_EVEN USART_CR1_PCE |
#define | USART_PARITY_ODD (USART_CR1_PCE | USART_CR1_PS) |
#define | USART_MODE_RX USART_CR1_RE |
#define | USART_MODE_TX USART_CR1_TE |
#define | USART_MODE_TX_RX (USART_CR1_TE |USART_CR1_RE) |
#define | USART_CLOCK_DISABLE 0x00000000U |
#define | USART_CLOCK_ENABLE USART_CR2_CLKEN |
#define | USART_POLARITY_LOW 0x00000000U |
#define | USART_POLARITY_HIGH USART_CR2_CPOL |
#define | USART_PHASE_1EDGE 0x00000000U |
#define | USART_PHASE_2EDGE USART_CR2_CPHA |
#define | USART_LASTBIT_DISABLE 0x00000000U |
#define | USART_LASTBIT_ENABLE USART_CR2_LBCL |
#define | USART_PRESCALER_DIV1 0x00000000U |
#define | USART_PRESCALER_DIV2 0x00000001U |
#define | USART_PRESCALER_DIV4 0x00000002U |
#define | USART_PRESCALER_DIV6 0x00000003U |
#define | USART_PRESCALER_DIV8 0x00000004U |
#define | USART_PRESCALER_DIV10 0x00000005U |
#define | USART_PRESCALER_DIV12 0x00000006U |
#define | USART_PRESCALER_DIV16 0x00000007U |
#define | USART_PRESCALER_DIV32 0x00000008U |
#define | USART_PRESCALER_DIV64 0x00000009U |
#define | USART_PRESCALER_DIV128 0x0000000AU |
#define | USART_PRESCALER_DIV256 0x0000000BU |
#define | USART_RXDATA_FLUSH_REQUEST USART_RQR_RXFRQ |
#define | USART_TXDATA_FLUSH_REQUEST USART_RQR_TXFRQ |
#define | USART_FLAG_TXFT USART_ISR_TXFT |
#define | USART_FLAG_RXFT USART_ISR_RXFT |
#define | USART_FLAG_RXFF USART_ISR_RXFF |
#define | USART_FLAG_TXFE USART_ISR_TXFE |
#define | USART_FLAG_REACK USART_ISR_REACK |
#define | USART_FLAG_TEACK USART_ISR_TEACK |
#define | USART_FLAG_BUSY USART_ISR_BUSY |
#define | USART_FLAG_UDR USART_ISR_UDR |
#define | USART_FLAG_TXE USART_ISR_TXE_TXFNF |
#define | USART_FLAG_TXFNF USART_ISR_TXE_TXFNF |
#define | USART_FLAG_RTOF USART_ISR_RTOF |
#define | USART_FLAG_TC USART_ISR_TC |
#define | USART_FLAG_RXNE USART_ISR_RXNE_RXFNE |
#define | USART_FLAG_RXFNE USART_ISR_RXNE_RXFNE |
#define | USART_FLAG_IDLE USART_ISR_IDLE |
#define | USART_FLAG_ORE USART_ISR_ORE |
#define | USART_FLAG_NE USART_ISR_NE |
#define | USART_FLAG_FE USART_ISR_FE |
#define | USART_FLAG_PE USART_ISR_PE |
#define | USART_IT_PE 0x0028U |
#define | USART_IT_TXE 0x0727U |
#define | USART_IT_TXFNF 0x0727U |
#define | USART_IT_TC 0x0626U |
#define | USART_IT_RXNE 0x0525U |
#define | USART_IT_RXFNE 0x0525U |
#define | USART_IT_IDLE 0x0424U |
#define | USART_IT_ERR 0x0060U |
#define | USART_IT_ORE 0x0300U |
#define | USART_IT_NE 0x0200U |
#define | USART_IT_FE 0x0100U |
#define | USART_IT_RXFF 0x183FU |
#define | USART_IT_TXFE 0x173EU |
#define | USART_IT_RXFT 0x1A7CU |
#define | USART_IT_TXFT 0x1B77U |
#define | USART_CLEAR_PEF USART_ICR_PECF |
#define | USART_CLEAR_FEF USART_ICR_FECF |
#define | USART_CLEAR_NEF USART_ICR_NECF |
#define | USART_CLEAR_OREF USART_ICR_ORECF |
#define | USART_CLEAR_IDLEF USART_ICR_IDLECF |
#define | USART_CLEAR_TCF USART_ICR_TCCF |
#define | USART_CLEAR_UDRF USART_ICR_UDRCF |
#define | USART_CLEAR_TXFECF USART_ICR_TXFECF |
#define | USART_CLEAR_RTOF USART_ICR_RTOCF |
#define | USART_IT_MASK 0x001FU |
#define | USART_CR_MASK 0x00E0U |
#define | USART_CR_POS 5U |
#define | USART_ISR_MASK 0x1F00U |
#define | USART_ISR_POS 8U |
#define | __HAL_USART_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_USART_STATE_RESET) |
Reset USART handle state. | |
#define | __HAL_USART_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
Check whether the specified USART flag is set or not. | |
#define | __HAL_USART_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
Clear the specified USART pending flag. | |
#define | __HAL_USART_CLEAR_PEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF) |
Clear the USART PE pending flag. | |
#define | __HAL_USART_CLEAR_FEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF) |
Clear the USART FE pending flag. | |
#define | __HAL_USART_CLEAR_NEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF) |
Clear the USART NE pending flag. | |
#define | __HAL_USART_CLEAR_OREFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF) |
Clear the USART ORE pending flag. | |
#define | __HAL_USART_CLEAR_IDLEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF) |
Clear the USART IDLE pending flag. | |
#define | __HAL_USART_CLEAR_TXFECF(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF) |
Clear the USART TX FIFO empty clear flag. | |
#define | __HAL_USART_CLEAR_UDRFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF) |
Clear SPI slave underrun error flag. | |
#define | __HAL_USART_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
Enable the specified USART interrupt. | |
#define | __HAL_USART_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
Disable the specified USART interrupt. | |
#define | __HAL_USART_GET_IT(__HANDLE__, __INTERRUPT__) |
Check whether the specified USART interrupt has occurred or not. | |
#define | __HAL_USART_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
Check whether the specified USART interrupt source is enabled or not. | |
#define | __HAL_USART_CLEAR_IT(__HANDLE__, __IT_CLEAR__) ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__)) |
Clear the specified USART ISR flag, in setting the proper ICR register flag. | |
#define | __HAL_USART_SEND_REQ(__HANDLE__, __REQ__) ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
Set a specific USART request flag. | |
#define | __HAL_USART_ONE_BIT_SAMPLE_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
Enable the USART one bit sample method. | |
#define | __HAL_USART_ONE_BIT_SAMPLE_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT) |
Disable the USART one bit sample method. | |
#define | __HAL_USART_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
Enable USART. | |
#define | __HAL_USART_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
Disable USART. | |
#define | USART_GET_DIV_FACTOR(__CLOCKPRESCALER__) |
Get USART clock division factor from clock prescaler value. | |
#define | USART_DIV_SAMPLING8(__PCLK__, __BAUD__, __CLOCKPRESCALER__) |
BRR division operation to set BRR register in 8-bit oversampling mode. | |
#define | USART_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__) |
Report the USART clock source. | |
#define | IS_USART_BAUDRATE(__BAUDRATE__) ((__BAUDRATE__) <= 12500000U) |
Check USART Baud rate. | |
#define | IS_USART_STOPBITS(__STOPBITS__) |
Ensure that USART frame number of stop bits is valid. | |
#define | IS_USART_PARITY(__PARITY__) |
Ensure that USART frame parity is valid. | |
#define | IS_USART_MODE(__MODE__) ((((__MODE__) & 0xFFFFFFF3U) == 0x00U) && ((__MODE__) != 0x00U)) |
Ensure that USART communication mode is valid. | |
#define | IS_USART_CLOCK(__CLOCK__) |
Ensure that USART clock state is valid. | |
#define | IS_USART_POLARITY(__CPOL__) (((__CPOL__) == USART_POLARITY_LOW) || ((__CPOL__) == USART_POLARITY_HIGH)) |
Ensure that USART frame polarity is valid. | |
#define | IS_USART_PHASE(__CPHA__) (((__CPHA__) == USART_PHASE_1EDGE) || ((__CPHA__) == USART_PHASE_2EDGE)) |
Ensure that USART frame phase is valid. | |
#define | IS_USART_LASTBIT(__LASTBIT__) |
Ensure that USART frame last bit clock pulse setting is valid. | |
#define | IS_USART_REQUEST_PARAMETER(__PARAM__) |
Ensure that USART request parameter is valid. | |
#define | IS_USART_PRESCALER(__CLOCKPRESCALER__) |
Ensure that USART Prescaler is valid. | |
Typedefs | |
typedef struct __USART_HandleTypeDef | USART_HandleTypeDef |
USART handle Structure definition. | |
Enumerations | |
enum | HAL_USART_StateTypeDef { HAL_USART_STATE_RESET = 0x00U , HAL_USART_STATE_READY = 0x01U , HAL_USART_STATE_BUSY = 0x02U , HAL_USART_STATE_BUSY_TX = 0x12U , HAL_USART_STATE_BUSY_RX = 0x22U , HAL_USART_STATE_BUSY_TX_RX = 0x32U , HAL_USART_STATE_TIMEOUT = 0x03U , HAL_USART_STATE_ERROR = 0x04U } |
HAL USART State structures definition. More... | |
enum | USART_ClockSourceTypeDef { USART_CLOCKSOURCE_D2PCLK1 = 0x00U , USART_CLOCKSOURCE_D2PCLK2 = 0x01U , USART_CLOCKSOURCE_PLL2 = 0x02U , USART_CLOCKSOURCE_PLL3 = 0x04U , USART_CLOCKSOURCE_HSI = 0x08U , USART_CLOCKSOURCE_CSI = 0x10U , USART_CLOCKSOURCE_LSE = 0x20U , USART_CLOCKSOURCE_UNDEFINED = 0x40U } |
USART clock sources definitions. More... | |
HAL_StatusTypeDef | HAL_USART_Init (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_DeInit (USART_HandleTypeDef *husart) |
void | HAL_USART_MspInit (USART_HandleTypeDef *husart) |
void | HAL_USART_MspDeInit (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_Transmit (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_USART_Receive (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_USART_TransmitReceive (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_USART_Transmit_IT (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_Receive_IT (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_TransmitReceive_IT (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_Transmit_DMA (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_Receive_DMA (USART_HandleTypeDef *husart, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_TransmitReceive_DMA (USART_HandleTypeDef *husart, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_USART_DMAPause (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_DMAResume (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_DMAStop (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_Abort (USART_HandleTypeDef *husart) |
HAL_StatusTypeDef | HAL_USART_Abort_IT (USART_HandleTypeDef *husart) |
void | HAL_USART_IRQHandler (USART_HandleTypeDef *husart) |
void | HAL_USART_TxHalfCpltCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_TxCpltCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_RxCpltCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_RxHalfCpltCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_TxRxCpltCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_ErrorCallback (USART_HandleTypeDef *husart) |
void | HAL_USART_AbortCpltCallback (USART_HandleTypeDef *husart) |
HAL_USART_StateTypeDef | HAL_USART_GetState (const USART_HandleTypeDef *husart) |
uint32_t | HAL_USART_GetError (const USART_HandleTypeDef *husart) |
