RTEMS 6.1-rc2
#define | __HAL_USART_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_USART_STATE_RESET) |
Reset USART handle state. | |
#define | __HAL_USART_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
Check whether the specified USART flag is set or not. | |
#define | __HAL_USART_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
Clear the specified USART pending flag. | |
#define | __HAL_USART_CLEAR_PEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF) |
Clear the USART PE pending flag. | |
#define | __HAL_USART_CLEAR_FEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF) |
Clear the USART FE pending flag. | |
#define | __HAL_USART_CLEAR_NEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF) |
Clear the USART NE pending flag. | |
#define | __HAL_USART_CLEAR_OREFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF) |
Clear the USART ORE pending flag. | |
#define | __HAL_USART_CLEAR_IDLEFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF) |
Clear the USART IDLE pending flag. | |
#define | __HAL_USART_CLEAR_TXFECF(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF) |
Clear the USART TX FIFO empty clear flag. | |
#define | __HAL_USART_CLEAR_UDRFLAG(__HANDLE__) __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF) |
Clear SPI slave underrun error flag. | |
#define | __HAL_USART_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
Enable the specified USART interrupt. | |
#define | __HAL_USART_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
Disable the specified USART interrupt. | |
#define | __HAL_USART_GET_IT(__HANDLE__, __INTERRUPT__) |
Check whether the specified USART interrupt has occurred or not. | |
#define | __HAL_USART_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
Check whether the specified USART interrupt source is enabled or not. | |
#define | __HAL_USART_CLEAR_IT(__HANDLE__, __IT_CLEAR__) ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__)) |
Clear the specified USART ISR flag, in setting the proper ICR register flag. | |
#define | __HAL_USART_SEND_REQ(__HANDLE__, __REQ__) ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
Set a specific USART request flag. | |
#define | __HAL_USART_ONE_BIT_SAMPLE_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
Enable the USART one bit sample method. | |
#define | __HAL_USART_ONE_BIT_SAMPLE_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT) |
Disable the USART one bit sample method. | |
#define | __HAL_USART_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
Enable USART. | |
#define | __HAL_USART_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
Disable USART. | |
#define __HAL_USART_CLEAR_FEFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_FEF) |
__HANDLE__ | specifies the USART Handle. |
None |
#define __HAL_USART_CLEAR_FLAG | ( | __HANDLE__, | |
__FLAG__ | |||
) | ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
__FLAG__ | specifies the flag to check. This parameter can be any combination of the following values:
None |
#define __HAL_USART_CLEAR_IDLEFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_IDLEF) |
None |
#define __HAL_USART_CLEAR_IT | ( | __HANDLE__, | |
__IT_CLEAR__ | |||
) | ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__)) |
__IT_CLEAR__ | specifies the interrupt clear register flag that needs to be set to clear the corresponding interrupt. This parameter can be one of the following values:
None |
#define __HAL_USART_CLEAR_NEFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_NEF) |
None |
#define __HAL_USART_CLEAR_OREFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_OREF) |
None |
#define __HAL_USART_CLEAR_PEFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_PEF) |
None |
#define __HAL_USART_CLEAR_TXFECF | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_TXFECF) |
None |
#define __HAL_USART_CLEAR_UDRFLAG | ( | __HANDLE__ | ) | __HAL_USART_CLEAR_FLAG((__HANDLE__), USART_CLEAR_UDRF) |
None |
#define __HAL_USART_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
Disable USART.
None |
#define __HAL_USART_DISABLE_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
__INTERRUPT__ | specifies the USART interrupt source to disable. This parameter can be one of the following values:
None |
#define __HAL_USART_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
Enable USART.
None |
#define __HAL_USART_ENABLE_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
__INTERRUPT__ | specifies the USART interrupt source to enable. This parameter can be one of the following values:
None |
#define __HAL_USART_GET_FLAG | ( | __HANDLE__, | |
__FLAG__ | |||
) | (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
__HANDLE__ | specifies the USART Handle |
__FLAG__ | specifies the flag to check. This parameter can be one of the following values:
The | new state of FLAG (TRUE or FALSE). |
#define __HAL_USART_GET_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
__INTERRUPT__ | specifies the USART interrupt source to check. This parameter can be one of the following values:
The | new state of INTERRUPT (SET or RESET). |
#define __HAL_USART_GET_IT_SOURCE | ( | __HANDLE__, | |
__INTERRUPT__ | |||
#define __HAL_USART_ONE_BIT_SAMPLE_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR3 &= ~USART_CR3_ONEBIT) |
None |
#define __HAL_USART_ONE_BIT_SAMPLE_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
None |
#define __HAL_USART_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_USART_STATE_RESET) |
__HANDLE__ | USART handle. |
None |
#define __HAL_USART_SEND_REQ | ( | __HANDLE__, | |
__REQ__ | |||
) | ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
__REQ__ | specifies the request flag to set. This parameter can be one of the following values:
None |
