RTEMS 6.1-rc2
Header file of OPAMP HAL module. More...
struct | OPAMP_InitTypeDef |
OPAMP Init structure definition More... | |
struct | OPAMP_HandleTypeDef |
OPAMP Handle Structure definition. More... | |
Typedefs | |
typedef uint32_t | HAL_OPAMP_TrimmingValueTypeDef |
HAl_OPAMP_TrimmingValueTypeDef definition. | |
Enumerations | |
enum | HAL_OPAMP_StateTypeDef { HAL_OPAMP_STATE_RESET = 0x00000000U , HAL_OPAMP_STATE_READY = 0x00000001U , HAL_OPAMP_STATE_CALIBBUSY = 0x00000002U , HAL_OPAMP_STATE_BUSY = 0x00000004U , HAL_OPAMP_STATE_BUSYLOCKED = 0x00000005U } |
HAL State structures definition More... | |
HAL_StatusTypeDef | HAL_OPAMP_Init (OPAMP_HandleTypeDef *hopamp) |
HAL_StatusTypeDef | HAL_OPAMP_DeInit (OPAMP_HandleTypeDef *hopamp) |
void | HAL_OPAMP_MspInit (OPAMP_HandleTypeDef *hopamp) |
void | HAL_OPAMP_MspDeInit (OPAMP_HandleTypeDef *hopamp) |
HAL_StatusTypeDef | HAL_OPAMP_Start (OPAMP_HandleTypeDef *hopamp) |
HAL_StatusTypeDef | HAL_OPAMP_Stop (OPAMP_HandleTypeDef *hopamp) |
HAL_StatusTypeDef | HAL_OPAMP_SelfCalibrate (OPAMP_HandleTypeDef *hopamp) |
HAL_StatusTypeDef | HAL_OPAMP_Lock (OPAMP_HandleTypeDef *hopamp) |
HAL_OPAMP_TrimmingValueTypeDef | HAL_OPAMP_GetTrimOffset (OPAMP_HandleTypeDef *hopamp, uint32_t trimmingoffset) |
HAL_OPAMP_StateTypeDef | HAL_OPAMP_GetState (OPAMP_HandleTypeDef *hopamp) |
