RTEMS 6.1-rc2
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_NO   0x00000000U
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0   OPAMP_CSR_PGGAIN_2
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS   OPAMP_CSR_PGGAIN_3
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS   (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3)
◆ OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0
In PGA mode, the inverting input is connected to VINM0
◆ OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS
In PGA mode, the inverting input is connected to VINM0 or bias
◆ OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS
In PGA mode, the inverting input is connected to VINM0 or bias , VINM1 connected for filtering
◆ OPAMP_PGA_CONNECT_INVERTINGINPUT_NO
In PGA mode, the inverting input is not connected
