RTEMS 6.1-rc2
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_irda.h File Reference
Header file of IRDA HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_irda_ex.h"
struct  IRDA_InitTypeDef
 IRDA Init Structure definition. More...
struct  IRDA_HandleTypeDef
 IRDA handle Structure definition. More...
#define HAL_IRDA_STATE_RESET   0x00000000U
#define HAL_IRDA_STATE_READY   0x00000020U
#define HAL_IRDA_STATE_BUSY   0x00000024U
#define HAL_IRDA_STATE_BUSY_TX   0x00000021U
#define HAL_IRDA_STATE_BUSY_RX   0x00000022U
#define HAL_IRDA_STATE_BUSY_TX_RX   0x00000023U
#define HAL_IRDA_STATE_TIMEOUT   0x000000A0U
#define HAL_IRDA_STATE_ERROR   0x000000E0U
#define HAL_IRDA_ERROR_NONE   (0x00000000U)
#define HAL_IRDA_ERROR_PE   (0x00000001U)
#define HAL_IRDA_ERROR_NE   (0x00000002U)
#define HAL_IRDA_ERROR_FE   (0x00000004U)
#define HAL_IRDA_ERROR_ORE   (0x00000008U)
#define HAL_IRDA_ERROR_DMA   (0x00000010U)
#define HAL_IRDA_ERROR_BUSY   (0x00000020U)
#define IRDA_PARITY_NONE   0x00000000U
#define IRDA_PARITY_EVEN   USART_CR1_PCE
#define IRDA_PARITY_ODD   (USART_CR1_PCE | USART_CR1_PS)
#define IRDA_MODE_RX   USART_CR1_RE
#define IRDA_MODE_TX   USART_CR1_TE
#define IRDA_MODE_TX_RX   (USART_CR1_TE |USART_CR1_RE)
#define IRDA_POWERMODE_NORMAL   0x00000000U
#define IRDA_POWERMODE_LOWPOWER   USART_CR3_IRLP
#define IRDA_PRESCALER_DIV1   0x00000000U
#define IRDA_PRESCALER_DIV2   0x00000001U
#define IRDA_PRESCALER_DIV4   0x00000002U
#define IRDA_PRESCALER_DIV6   0x00000003U
#define IRDA_PRESCALER_DIV8   0x00000004U
#define IRDA_PRESCALER_DIV10   0x00000005U
#define IRDA_PRESCALER_DIV12   0x00000006U
#define IRDA_PRESCALER_DIV16   0x00000007U
#define IRDA_PRESCALER_DIV32   0x00000008U
#define IRDA_PRESCALER_DIV64   0x00000009U
#define IRDA_PRESCALER_DIV128   0x0000000AU
#define IRDA_PRESCALER_DIV256   0x0000000BU
#define IRDA_STATE_DISABLE   0x00000000U
#define IRDA_STATE_ENABLE   USART_CR1_UE
#define IRDA_MODE_DISABLE   0x00000000U
#define IRDA_MODE_ENABLE   USART_CR3_IREN
#define IRDA_ONE_BIT_SAMPLE_DISABLE   0x00000000U
#define IRDA_ONE_BIT_SAMPLE_ENABLE   USART_CR3_ONEBIT
#define IRDA_DMA_TX_DISABLE   0x00000000U
#define IRDA_DMA_TX_ENABLE   USART_CR3_DMAT
#define IRDA_DMA_RX_DISABLE   0x00000000U
#define IRDA_DMA_RX_ENABLE   USART_CR3_DMAR
#define IRDA_AUTOBAUD_REQUEST   USART_RQR_ABRRQ
#define IRDA_RXDATA_FLUSH_REQUEST   USART_RQR_RXFRQ
#define IRDA_TXDATA_FLUSH_REQUEST   USART_RQR_TXFRQ
#define IRDA_FLAG_REACK   USART_ISR_REACK
#define IRDA_FLAG_TEACK   USART_ISR_TEACK
#define IRDA_FLAG_BUSY   USART_ISR_BUSY
#define IRDA_FLAG_ABRF   USART_ISR_ABRF
#define IRDA_FLAG_ABRE   USART_ISR_ABRE
#define IRDA_FLAG_TXE   USART_ISR_TXE_TXFNF
#define IRDA_FLAG_TC   USART_ISR_TC
#define IRDA_FLAG_RXNE   USART_ISR_RXNE_RXFNE
#define IRDA_FLAG_ORE   USART_ISR_ORE
#define IRDA_FLAG_NE   USART_ISR_NE
#define IRDA_FLAG_FE   USART_ISR_FE
#define IRDA_FLAG_PE   USART_ISR_PE
#define IRDA_IT_PE   0x0028U
#define IRDA_IT_TXE   0x0727U
#define IRDA_IT_TC   0x0626U
#define IRDA_IT_RXNE   0x0525U
#define IRDA_IT_IDLE   0x0424U
#define IRDA_IT_ERR   0x0060U
#define IRDA_IT_ORE   0x0300U
#define IRDA_IT_NE   0x0200U
#define IRDA_IT_FE   0x0100U
#define IRDA_CLEAR_PEF   USART_ICR_PECF
#define IRDA_CLEAR_FEF   USART_ICR_FECF
#define IRDA_CLEAR_NEF   USART_ICR_NECF
#define IRDA_CLEAR_OREF   USART_ICR_ORECF
#define IRDA_CLEAR_IDLEF   USART_ICR_IDLECF
#define IRDA_CLEAR_TCF   USART_ICR_TCCF
#define IRDA_IT_MASK   0x001FU
#define IRDA_CR_MASK   0x00E0U
#define IRDA_CR_POS   5U
#define IRDA_ISR_MASK   0x1F00U
#define IRDA_ISR_POS   8U
#define __HAL_IRDA_RESET_HANDLE_STATE(__HANDLE__)
 Reset IRDA handle state.
#define __HAL_IRDA_FLUSH_DRREGISTER(__HANDLE__)
 Flush the IRDA DR register.
#define __HAL_IRDA_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ICR = (__FLAG__))
 Clear the specified IRDA pending flag.
#define __HAL_IRDA_CLEAR_PEFLAG(__HANDLE__)   __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_PEF)
 Clear the IRDA PE pending flag.
#define __HAL_IRDA_CLEAR_FEFLAG(__HANDLE__)   __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_FEF)
 Clear the IRDA FE pending flag.
#define __HAL_IRDA_CLEAR_NEFLAG(__HANDLE__)   __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_NEF)
 Clear the IRDA NE pending flag.
#define __HAL_IRDA_CLEAR_OREFLAG(__HANDLE__)   __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_OREF)
 Clear the IRDA ORE pending flag.
#define __HAL_IRDA_CLEAR_IDLEFLAG(__HANDLE__)   __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_IDLEF)
 Clear the IRDA IDLE pending flag.
#define __HAL_IRDA_GET_FLAG(__HANDLE__, __FLAG__)   (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__))
 Check whether the specified IRDA flag is set or not.
#define __HAL_IRDA_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified IRDA interrupt.
#define __HAL_IRDA_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified IRDA interrupt.
#define __HAL_IRDA_GET_IT(__HANDLE__, __INTERRUPT__)    ((((__HANDLE__)->Instance->ISR& (0x01U << (((__INTERRUPT__) & IRDA_ISR_MASK)>>IRDA_ISR_POS))) != 0U) ? SET : RESET)
 Check whether the specified IRDA interrupt has occurred or not.
#define __HAL_IRDA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified IRDA interrupt source is enabled or not.
#define __HAL_IRDA_CLEAR_IT(__HANDLE__, __IT_CLEAR__)   ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__))
 Clear the specified IRDA ISR flag, in setting the proper ICR register flag.
#define __HAL_IRDA_SEND_REQ(__HANDLE__, __REQ__)   ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__))
 Set a specific IRDA request flag.
#define __HAL_IRDA_ONE_BIT_SAMPLE_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT)
 Enable the IRDA one bit sample method.
#define __HAL_IRDA_ONE_BIT_SAMPLE_DISABLE(__HANDLE__)
 Disable the IRDA one bit sample method.
#define __HAL_IRDA_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE)
 Enable UART/USART associated to IRDA Handle.
#define __HAL_IRDA_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE)
 Disable UART/USART associated to IRDA Handle.
#define IS_IRDA_BAUDRATE(__BAUDRATE__)   ((__BAUDRATE__) < 115201U)
 Ensure that IRDA Baud rate is less or equal to maximum value.
#define IS_IRDA_PRESCALER(__PRESCALER__)   ((__PRESCALER__) > 0U)
 Ensure that IRDA prescaler value is strictly larger than 0.
#define IS_IRDA_PARITY(__PARITY__)
 Ensure that IRDA frame parity is valid.
#define IS_IRDA_TX_RX_MODE(__MODE__)
 Ensure that IRDA communication mode is valid.
#define IS_IRDA_POWERMODE(__MODE__)
 Ensure that IRDA power mode is valid.
#define IS_IRDA_CLOCKPRESCALER(__CLOCKPRESCALER__)
 Ensure that IRDA clock Prescaler is valid.
#define IS_IRDA_STATE(__STATE__)
 Ensure that IRDA state is valid.
#define IS_IRDA_MODE(__MODE__)
 Ensure that IRDA associated UART/USART mode is valid.
#define IS_IRDA_ONE_BIT_SAMPLE(__ONEBIT__)
 Ensure that IRDA sampling rate is valid.
#define IS_IRDA_DMA_TX(__DMATX__)
 Ensure that IRDA DMA TX mode is valid.
#define IS_IRDA_DMA_RX(__DMARX__)
 Ensure that IRDA DMA RX mode is valid.
#define IS_IRDA_REQUEST_PARAMETER(__PARAM__)
 Ensure that IRDA request is valid.
typedef uint32_t HAL_IRDA_StateTypeDef
 HAL IRDA State definition.
enum  IRDA_ClockSourceTypeDef {
  IRDA_CLOCKSOURCE_D2PCLK1 = 0x11U , IRDA_CLOCKSOURCE_D2PCLK2 = 0x12U , IRDA_CLOCKSOURCE_PLL2Q = 0x14U , IRDA_CLOCKSOURCE_PLL3Q = 0x18U ,
  IRDA_CLOCKSOURCE_HSI = 0x02U , IRDA_CLOCKSOURCE_CSI = 0x08U , IRDA_CLOCKSOURCE_LSE = 0x10U , IRDA_CLOCKSOURCE_UNDEFINED = 0x20U
 IRDA clock sources definition. More...
HAL_StatusTypeDef HAL_IRDA_Init (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_DeInit (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_MspInit (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_MspDeInit (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_Transmit (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_IRDA_Receive (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_IRDA_Transmit_IT (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_IRDA_Receive_IT (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_IRDA_Transmit_DMA (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_IRDA_Receive_DMA (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_IRDA_DMAPause (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_DMAResume (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_DMAStop (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_Abort (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_AbortTransmit (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_AbortReceive (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_Abort_IT (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_AbortTransmit_IT (IRDA_HandleTypeDef *hirda)
HAL_StatusTypeDef HAL_IRDA_AbortReceive_IT (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_IRQHandler (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_TxCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_RxCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_TxHalfCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_RxHalfCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_ErrorCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_AbortCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_AbortTransmitCpltCallback (IRDA_HandleTypeDef *hirda)
void HAL_IRDA_AbortReceiveCpltCallback (IRDA_HandleTypeDef *hirda)
HAL_IRDA_StateTypeDef HAL_IRDA_GetState (const IRDA_HandleTypeDef *hirda)
uint32_t HAL_IRDA_GetError (const IRDA_HandleTypeDef *hirda)
Author
MCD Application Team
Attention
