RTEMS 6.1-rc2
#define IS_IRDA_BAUDRATE(__BAUDRATE__)   ((__BAUDRATE__) < 115201U)
 Ensure that IRDA Baud rate is less or equal to maximum value.
#define IS_IRDA_PRESCALER(__PRESCALER__)   ((__PRESCALER__) > 0U)
 Ensure that IRDA prescaler value is strictly larger than 0.
#define IS_IRDA_PARITY(__PARITY__)
 Ensure that IRDA frame parity is valid.
#define IS_IRDA_TX_RX_MODE(__MODE__)
 Ensure that IRDA communication mode is valid.
#define IS_IRDA_POWERMODE(__MODE__)
 Ensure that IRDA power mode is valid.
#define IS_IRDA_CLOCKPRESCALER(__CLOCKPRESCALER__)
 Ensure that IRDA clock Prescaler is valid.
#define IS_IRDA_STATE(__STATE__)
 Ensure that IRDA state is valid.
#define IS_IRDA_MODE(__MODE__)
 Ensure that IRDA associated UART/USART mode is valid.
#define IS_IRDA_ONE_BIT_SAMPLE(__ONEBIT__)
 Ensure that IRDA sampling rate is valid.
#define IS_IRDA_DMA_TX(__DMATX__)
 Ensure that IRDA DMA TX mode is valid.
#define IS_IRDA_DMA_RX(__DMARX__)
 Ensure that IRDA DMA RX mode is valid.
#define IS_IRDA_REQUEST_PARAMETER(__PARAM__)
 Ensure that IRDA request is valid.
◆ IS_IRDA_BAUDRATE
#define IS_IRDA_BAUDRATE (   __BAUDRATE__)    ((__BAUDRATE__) < 115201U)
Parameters
__BAUDRATE__specifies the IRDA Baudrate set by the user.
Return values
Trueor False
◆ IS_IRDA_CLOCKPRESCALER
#define IS_IRDA_CLOCKPRESCALER (   __CLOCKPRESCALER__)
Value:
(((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV1) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV2) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV4) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV6) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV8) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV10) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV12) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV16) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV32) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV64) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV128) || \
((__CLOCKPRESCALER__) == IRDA_PRESCALER_DIV256))
#define IRDA_PRESCALER_DIV6
Definition: stm32h7xx_hal_irda.h:323
#define IRDA_PRESCALER_DIV10
Definition: stm32h7xx_hal_irda.h:325
#define IRDA_PRESCALER_DIV2
Definition: stm32h7xx_hal_irda.h:321
#define IRDA_PRESCALER_DIV64
Definition: stm32h7xx_hal_irda.h:329
#define IRDA_PRESCALER_DIV16
Definition: stm32h7xx_hal_irda.h:327
#define IRDA_PRESCALER_DIV128
Definition: stm32h7xx_hal_irda.h:330
#define IRDA_PRESCALER_DIV8
Definition: stm32h7xx_hal_irda.h:324
#define IRDA_PRESCALER_DIV4
Definition: stm32h7xx_hal_irda.h:322
#define IRDA_PRESCALER_DIV256
Definition: stm32h7xx_hal_irda.h:331
#define IRDA_PRESCALER_DIV32
Definition: stm32h7xx_hal_irda.h:328
Definition: stm32h7xx_hal_irda.h:326
Definition: stm32h7xx_hal_irda.h:320
Parameters
__CLOCKPRESCALER__IRDA clock Prescaler value.
Return values
SET(CLOCKPRESCALER is valid) or RESET (CLOCKPRESCALER is invalid)
◆ IS_IRDA_DMA_RX
#define IS_IRDA_DMA_RX (   __DMARX__)
Value:
(((__DMARX__) == IRDA_DMA_RX_DISABLE) || \
((__DMARX__) == IRDA_DMA_RX_ENABLE))
#define IRDA_DMA_RX_DISABLE
Definition: stm32h7xx_hal_irda.h:380
#define IRDA_DMA_RX_ENABLE
Definition: stm32h7xx_hal_irda.h:381
Parameters
__DMARX__IRDA DMA RX mode.
Return values
SET(DMARX is valid) or RESET (DMARX is invalid)
◆ IS_IRDA_DMA_TX
#define IS_IRDA_DMA_TX (   __DMATX__)
Value:
(((__DMATX__) == IRDA_DMA_TX_DISABLE) || \
((__DMATX__) == IRDA_DMA_TX_ENABLE))
#define IRDA_DMA_TX_ENABLE
Definition: stm32h7xx_hal_irda.h:371
#define IRDA_DMA_TX_DISABLE
Definition: stm32h7xx_hal_irda.h:370
Parameters
__DMATX__IRDA DMA TX mode.
Return values
SET(DMATX is valid) or RESET (DMATX is invalid)
◆ IS_IRDA_MODE
#define IS_IRDA_MODE (   __MODE__)
Value:
(((__MODE__) == IRDA_MODE_DISABLE) || \
((__MODE__) == IRDA_MODE_ENABLE))
#define IRDA_MODE_DISABLE
Definition: stm32h7xx_hal_irda.h:350
#define IRDA_MODE_ENABLE
Definition: stm32h7xx_hal_irda.h:351
Parameters
__MODE__IRDA associated UART/USART mode.
Return values
SET(MODE is valid) or RESET (MODE is invalid)
◆ IS_IRDA_ONE_BIT_SAMPLE
#define IS_IRDA_ONE_BIT_SAMPLE (   __ONEBIT__)
Value:
(((__ONEBIT__) == IRDA_ONE_BIT_SAMPLE_DISABLE) || \
((__ONEBIT__) == IRDA_ONE_BIT_SAMPLE_ENABLE))
#define IRDA_ONE_BIT_SAMPLE_ENABLE
Definition: stm32h7xx_hal_irda.h:361
#define IRDA_ONE_BIT_SAMPLE_DISABLE
Definition: stm32h7xx_hal_irda.h:360
Parameters
__ONEBIT__IRDA sampling rate.
Return values
SET(ONEBIT is valid) or RESET (ONEBIT is invalid)
◆ IS_IRDA_PARITY
#define IS_IRDA_PARITY (   __PARITY__)
Value:
(((__PARITY__) == IRDA_PARITY_NONE) || \
((__PARITY__) == IRDA_PARITY_EVEN) || \
((__PARITY__) == IRDA_PARITY_ODD))
#define IRDA_PARITY_EVEN
Definition: stm32h7xx_hal_irda.h:289
#define IRDA_PARITY_ODD
Definition: stm32h7xx_hal_irda.h:290
#define IRDA_PARITY_NONE
Definition: stm32h7xx_hal_irda.h:288
Parameters
__PARITY__IRDA frame parity.
Return values
SET(PARITY is valid) or RESET (PARITY is invalid)
◆ IS_IRDA_POWERMODE
#define IS_IRDA_POWERMODE (   __MODE__)
Value:
(((__MODE__) == IRDA_POWERMODE_LOWPOWER) || \
((__MODE__) == IRDA_POWERMODE_NORMAL))
#define IRDA_POWERMODE_LOWPOWER
Definition: stm32h7xx_hal_irda.h:311
#define IRDA_POWERMODE_NORMAL
Definition: stm32h7xx_hal_irda.h:310
Parameters
__MODE__IRDA power mode.
Return values
◆ IS_IRDA_PRESCALER
#define IS_IRDA_PRESCALER (   __PRESCALER__)    ((__PRESCALER__) > 0U)
Parameters
__PRESCALER__specifies the IRDA prescaler value set by the user.
Return values
Trueor False
◆ IS_IRDA_REQUEST_PARAMETER
#define IS_IRDA_REQUEST_PARAMETER (   __PARAM__)
Value:
(((__PARAM__) == IRDA_AUTOBAUD_REQUEST) || \
((__PARAM__) == IRDA_RXDATA_FLUSH_REQUEST) || \
((__PARAM__) == IRDA_TXDATA_FLUSH_REQUEST))
#define IRDA_TXDATA_FLUSH_REQUEST
Definition: stm32h7xx_hal_irda.h:392
#define IRDA_AUTOBAUD_REQUEST
Definition: stm32h7xx_hal_irda.h:390
#define IRDA_RXDATA_FLUSH_REQUEST
Definition: stm32h7xx_hal_irda.h:391
Parameters
__PARAM__IRDA request.
Return values
SET(PARAM is valid) or RESET (PARAM is invalid)
◆ IS_IRDA_STATE
#define IS_IRDA_STATE (   __STATE__)
Value:
(((__STATE__) == IRDA_STATE_DISABLE) || \
((__STATE__) == IRDA_STATE_ENABLE))
#define IRDA_STATE_ENABLE
Definition: stm32h7xx_hal_irda.h:341
#define IRDA_STATE_DISABLE
Definition: stm32h7xx_hal_irda.h:340
Parameters
__STATE__IRDA state mode.
Return values
SET(STATE is valid) or RESET (STATE is invalid)
◆ IS_IRDA_TX_RX_MODE
#define IS_IRDA_TX_RX_MODE (   __MODE__)
Value:
((((__MODE__)\
& (~((uint32_t)(IRDA_MODE_TX_RX)))) == 0x00U) && ((__MODE__) != 0x00U))
#define IRDA_MODE_TX_RX
Definition: stm32h7xx_hal_irda.h:301
Parameters
__MODE__IRDA communication mode.
Return values
