RTEMS 6.1-rc2
Data Structures | Macros | Typedefs
spwtdp-regs.h File Reference
This header file defines the SPWTDP register block interface. More...
#include <stdint.h>
struct  spwtdp
 This structure defines the SPWTDP register block memory map. More...
#define SPWTDP_CONF0_JE   0x1000000U
#define SPWTDP_CONF0_ST   0x200000U
#define SPWTDP_CONF0_EP   0x100000U
#define SPWTDP_CONF0_ET   0x80000U
#define SPWTDP_CONF0_SP   0x40000U
#define SPWTDP_CONF0_SE   0x20000U
#define SPWTDP_CONF0_LE   0x10000U
#define SPWTDP_CONF0_AE   0x8000U
#define SPWTDP_CONF0_MAPPING_SHIFT   8
#define SPWTDP_CONF0_MAPPING_MASK   0x1f00U
#define SPWTDP_CONF0_MAPPING_GET(_reg)
#define SPWTDP_CONF0_MAPPING_SET(_reg, _val)
#define SPWTDP_CONF0_MAPPING(_val)
#define SPWTDP_CONF0_TD   0x80U
#define SPWTDP_CONF0_MU   0x40U
#define SPWTDP_CONF0_SEL_SHIFT   4
#define SPWTDP_CONF0_SEL_MASK   0x30U
#define SPWTDP_CONF0_SEL_GET(_reg)
#define SPWTDP_CONF0_SEL_SET(_reg, _val)
#define SPWTDP_CONF0_SEL(_val)
#define SPWTDP_CONF0_ME   0x8U
#define SPWTDP_CONF0_RE   0x4U
#define SPWTDP_CONF0_TE   0x2U
#define SPWTDP_CONF0_RS   0x1U
#define SPWTDP_CONF3_STM_SHIFT   16
#define SPWTDP_CONF3_STM_MASK   0x3f0000U
#define SPWTDP_CONF3_STM_GET(_reg)
#define SPWTDP_CONF3_STM_SET(_reg, _val)
#define SPWTDP_CONF3_STM(_val)
#define SPWTDP_CONF3_DI64R   0x2000U
#define SPWTDP_CONF3_DI64T   0x1000U
#define SPWTDP_CONF3_DI64   0x800U
#define SPWTDP_CONF3_DI   0x400U
#define SPWTDP_CONF3_INRX_SHIFT   5
#define SPWTDP_CONF3_INRX_MASK   0x3e0U
#define SPWTDP_CONF3_INRX_GET(_reg)
#define SPWTDP_CONF3_INRX_SET(_reg, _val)
#define SPWTDP_CONF3_INRX(_val)
#define SPWTDP_CONF3_INTX_SHIFT   0
#define SPWTDP_CONF3_INTX_MASK   0x1fU
#define SPWTDP_CONF3_INTX_GET(_reg)
#define SPWTDP_CONF3_INTX_SET(_reg, _val)
#define SPWTDP_CONF3_INTX(_val)
#define SPWTDP_CTRL_NC   0x80000000U
#define SPWTDP_CTRL_IS   0x40000000U
#define SPWTDP_CTRL_SPWTC_SHIFT   16
#define SPWTDP_CTRL_SPWTC_MASK   0xff0000U
#define SPWTDP_CTRL_SPWTC_GET(_reg)
#define SPWTDP_CTRL_SPWTC_SET(_reg, _val)
#define SPWTDP_CTRL_SPWTC(_val)
#define SPWTDP_CTRL_CPF_SHIFT   0
#define SPWTDP_CTRL_CPF_MASK   0xffffU
#define SPWTDP_CTRL_CPF_GET(_reg)
#define SPWTDP_CTRL_CPF_SET(_reg, _val)
#define SPWTDP_CTRL_CPF(_val)
#define SPWTDP_CET0_CET0_SHIFT   0
#define SPWTDP_CET0_CET0_MASK   0xffffffffU
#define SPWTDP_CET0_CET0_GET(_reg)
#define SPWTDP_CET0_CET0_SET(_reg, _val)
#define SPWTDP_CET0_CET0(_val)
#define SPWTDP_CET1_CET1_SHIFT   0
#define SPWTDP_CET1_CET1_MASK   0xffffffffU
#define SPWTDP_CET1_CET1_GET(_reg)
#define SPWTDP_CET1_CET1_SET(_reg, _val)
#define SPWTDP_CET1_CET1(_val)
#define SPWTDP_CET2_CET2_SHIFT   0
#define SPWTDP_CET2_CET2_MASK   0xffffffffU
#define SPWTDP_CET2_CET2_GET(_reg)
#define SPWTDP_CET2_CET2_SET(_reg, _val)
#define SPWTDP_CET2_CET2(_val)
#define SPWTDP_CET3_CET3_SHIFT   0
#define SPWTDP_CET3_CET3_MASK   0xffffffffU
#define SPWTDP_CET3_CET3_GET(_reg)
#define SPWTDP_CET3_CET3_SET(_reg, _val)
#define SPWTDP_CET3_CET3(_val)
#define SPWTDP_CET4_CET4_SHIFT   24
#define SPWTDP_CET4_CET4_MASK   0xff000000U
#define SPWTDP_CET4_CET4_GET(_reg)
#define SPWTDP_CET4_CET4_SET(_reg, _val)
#define SPWTDP_CET4_CET4(_val)
#define SPWTDP_DPF_DPF_SHIFT   0
#define SPWTDP_DPF_DPF_MASK   0xffffU
#define SPWTDP_DPF_DPF_GET(_reg)
#define SPWTDP_DPF_DPF_SET(_reg, _val)
#define SPWTDP_DPF_DPF(_val)
#define SPWTDP_DET0_DET0_SHIFT   0
#define SPWTDP_DET0_DET0_MASK   0xffffffffU
#define SPWTDP_DET0_DET0_GET(_reg)
#define SPWTDP_DET0_DET0_SET(_reg, _val)
#define SPWTDP_DET0_DET0(_val)
#define SPWTDP_DET1_DET1_SHIFT   0
#define SPWTDP_DET1_DET1_MASK   0xffffffffU
#define SPWTDP_DET1_DET1_GET(_reg)
#define SPWTDP_DET1_DET1_SET(_reg, _val)
#define SPWTDP_DET1_DET1(_val)
#define SPWTDP_DET2_DET2_SHIFT   0
#define SPWTDP_DET2_DET2_MASK   0xffffffffU
#define SPWTDP_DET2_DET2_GET(_reg)
#define SPWTDP_DET2_DET2_SET(_reg, _val)
#define SPWTDP_DET2_DET2(_val)
#define SPWTDP_DET3_DET3_SHIFT   0
#define SPWTDP_DET3_DET3_MASK   0xffffffffU
#define SPWTDP_DET3_DET3_GET(_reg)
#define SPWTDP_DET3_DET3_SET(_reg, _val)
#define SPWTDP_DET3_DET3(_val)
#define SPWTDP_DET4_DET4_SHIFT   24
#define SPWTDP_DET4_DET4_MASK   0xff000000U
#define SPWTDP_DET4_DET4_GET(_reg)
#define SPWTDP_DET4_DET4_SET(_reg, _val)
#define SPWTDP_DET4_DET4(_val)
#define SPWTDP_TRPFRX_TRPF_SHIFT   0
#define SPWTDP_TRPFRX_TRPF_MASK   0xffffU
#define SPWTDP_TRPFRX_TRPF_GET(_reg)
#define SPWTDP_TRPFRX_TRPF_SET(_reg, _val)
#define SPWTDP_TRPFRX_TRPF(_val)
#define SPWTDP_TR0_TR0_SHIFT   0
#define SPWTDP_TR0_TR0_MASK   0xffffffffU
#define SPWTDP_TR0_TR0_GET(_reg)
#define SPWTDP_TR0_TR0_SET(_reg, _val)
#define SPWTDP_TR0_TR0(_val)
#define SPWTDP_TR1_TR1_SHIFT   0
#define SPWTDP_TR1_TR1_MASK   0xffffffffU
#define SPWTDP_TR1_TR1_GET(_reg)
#define SPWTDP_TR1_TR1_SET(_reg, _val)
#define SPWTDP_TR1_TR1(_val)
#define SPWTDP_TR2_TR2_SHIFT   0
#define SPWTDP_TR2_TR2_MASK   0xffffffffU
#define SPWTDP_TR2_TR2_GET(_reg)
#define SPWTDP_TR2_TR2_SET(_reg, _val)
#define SPWTDP_TR2_TR2(_val)
#define SPWTDP_TR3_TR3_SHIFT   0
#define SPWTDP_TR3_TR3_MASK   0xffffffffU
#define SPWTDP_TR3_TR3_GET(_reg)
#define SPWTDP_TR3_TR3_SET(_reg, _val)
#define SPWTDP_TR3_TR3(_val)
#define SPWTDP_TR4_TR4_SHIFT   24
#define SPWTDP_TR4_TR4_MASK   0xff000000U
#define SPWTDP_TR4_TR4_GET(_reg)
#define SPWTDP_TR4_TR4_SET(_reg, _val)
#define SPWTDP_TR4_TR4(_val)
#define SPWTDP_TTPFTX_TSTC_SHIFT   24
#define SPWTDP_TTPFTX_TSTC_MASK   0xff000000U
#define SPWTDP_TTPFTX_TSTC_GET(_reg)
#define SPWTDP_TTPFTX_TSTC_SET(_reg, _val)
#define SPWTDP_TTPFTX_TSTC(_val)
#define SPWTDP_TTPFTX_TTPF_SHIFT   0
#define SPWTDP_TTPFTX_TTPF_MASK   0xffffU
#define SPWTDP_TTPFTX_TTPF_GET(_reg)
#define SPWTDP_TTPFTX_TTPF_SET(_reg, _val)
#define SPWTDP_TTPFTX_TTPF(_val)
#define SPWTDP_TT0_TT0_SHIFT   0
#define SPWTDP_TT0_TT0_MASK   0xffffffffU
#define SPWTDP_TT0_TT0_GET(_reg)
#define SPWTDP_TT0_TT0_SET(_reg, _val)
#define SPWTDP_TT0_TT0(_val)
#define SPWTDP_TT1_TT1_SHIFT   0
#define SPWTDP_TT1_TT1_MASK   0xffffffffU
#define SPWTDP_TT1_TT1_GET(_reg)
#define SPWTDP_TT1_TT1_SET(_reg, _val)
#define SPWTDP_TT1_TT1(_val)
#define SPWTDP_TT2_TT2_SHIFT   0
#define SPWTDP_TT2_TT2_MASK   0xffffffffU
#define SPWTDP_TT2_TT2_GET(_reg)
#define SPWTDP_TT2_TT2_SET(_reg, _val)
#define SPWTDP_TT2_TT2(_val)
#define SPWTDP_TT3_TT3_SHIFT   0
#define SPWTDP_TT3_TT3_MASK   0xffffffffU
#define SPWTDP_TT3_TT3_GET(_reg)
#define SPWTDP_TT3_TT3_SET(_reg, _val)
#define SPWTDP_TT3_TT3(_val)
#define SPWTDP_TT4_TT4_SHIFT   24
#define SPWTDP_TT4_TT4_MASK   0xff000000U
#define SPWTDP_TT4_TT4_GET(_reg)
#define SPWTDP_TT4_TT4_SET(_reg, _val)
#define SPWTDP_TT4_TT4(_val)
#define SPWTDP_LPF_LPF_SHIFT   0
#define SPWTDP_LPF_LPF_MASK   0xffffU
#define SPWTDP_LPF_LPF_GET(_reg)
#define SPWTDP_LPF_LPF_SET(_reg, _val)
#define SPWTDP_LPF_LPF(_val)
#define SPWTDP_IE_NCTCE   0x80000U
#define SPWTDP_IE_SETE   0x400U
#define SPWTDP_IE_EDIE3   0x200U
#define SPWTDP_IE_EDIE2   0x100U
#define SPWTDP_IE_EDIE1   0x80U
#define SPWTDP_IE_EDIE0   0x40U
#define SPWTDP_IE_DITE   0x20U
#define SPWTDP_IE_DIRE   0x10U
#define SPWTDP_IE_TTE   0x8U
#define SPWTDP_IE_TME   0x4U
#define SPWTDP_IE_TRE   0x2U
#define SPWTDP_IE_SE   0x1U
#define SPWTDP_DC_DC_SHIFT   0
#define SPWTDP_DC_DC_MASK   0x7fffU
#define SPWTDP_DC_DC_GET(_reg)
#define SPWTDP_DC_DC_SET(_reg, _val)
#define SPWTDP_DC_DC(_val)
#define SPWTDP_DS_EN   0x80000000U
#define SPWTDP_DS_CD_SHIFT   0
#define SPWTDP_DS_CD_MASK   0xffffffU
#define SPWTDP_DS_CD_GET(_reg)
#define SPWTDP_DS_CD_SET(_reg, _val)
#define SPWTDP_DS_CD(_val)
#define SPWTDP_EDM0_EDM0_SHIFT   0
#define SPWTDP_EDM0_EDM0_MASK   0xffffffffU
#define SPWTDP_EDM0_EDM0_GET(_reg)
#define SPWTDP_EDM0_EDM0_SET(_reg, _val)
#define SPWTDP_EDM0_EDM0(_val)
#define SPWTDP_EDPF0_EDPF0_SHIFT   0
#define SPWTDP_EDPF0_EDPF0_MASK   0xffffU
#define SPWTDP_EDPF0_EDPF0_GET(_reg)
#define SPWTDP_EDPF0_EDPF0_SET(_reg, _val)
#define SPWTDP_EDPF0_EDPF0(_val)
#define SPWTDP_ED0ET0_ED0ET0_SHIFT   0
#define SPWTDP_ED0ET0_ED0ET0_MASK   0xffffffffU
#define SPWTDP_ED0ET0_ED0ET0_GET(_reg)
#define SPWTDP_ED0ET0_ED0ET0_SET(_reg, _val)
#define SPWTDP_ED0ET0_ED0ET0(_val)
#define SPWTDP_ED0ET1_ED0ET1_SHIFT   0
#define SPWTDP_ED0ET1_ED0ET1_MASK   0xffffffffU
#define SPWTDP_ED0ET1_ED0ET1_GET(_reg)
#define SPWTDP_ED0ET1_ED0ET1_SET(_reg, _val)
#define SPWTDP_ED0ET1_ED0ET1(_val)
#define SPWTDP_ED0ET2_ED0ET2_SHIFT   0
#define SPWTDP_ED0ET2_ED0ET2_MASK   0xffffffffU
#define SPWTDP_ED0ET2_ED0ET2_GET(_reg)
#define SPWTDP_ED0ET2_ED0ET2_SET(_reg, _val)
#define SPWTDP_ED0ET2_ED0ET2(_val)
#define SPWTDP_ED0ET3_ED0ET3_SHIFT   0
#define SPWTDP_ED0ET3_ED0ET3_MASK   0xffffffffU
#define SPWTDP_ED0ET3_ED0ET3_GET(_reg)
#define SPWTDP_ED0ET3_ED0ET3_SET(_reg, _val)
#define SPWTDP_ED0ET3_ED0ET3(_val)
#define SPWTDP_ED0ET4_ED0ET4_SHIFT   24
#define SPWTDP_ED0ET4_ED0ET4_MASK   0xff000000U
#define SPWTDP_ED0ET4_ED0ET4_GET(_reg)
#define SPWTDP_ED0ET4_ED0ET4_SET(_reg, _val)
#define SPWTDP_ED0ET4_ED0ET4(_val)
typedef struct spwtdp spwtdp
