RTEMS 6.1-rc2
Modules | Files | Data Structures | Typedefs
This group contains the SPWTDP interfaces. More...
 Command Elapsed Time 0 (CET0)
 This group contains register bit definitions.
 Command Elapsed Time 1 (CET1)
 Command Elapsed Time 2 (CET2)
 Command Elapsed Time 3 (CET3)
 Command Elapsed Time 4 (CET4)
 Configuration 0 (CONF0)
 Configuration 3 (CONF3)
 Control (CTRL)
 Datation Elapsed Time 0 (DET0)
 Datation Elapsed Time 1 (DET1)
 Datation Elapsed Time 2 (DET2)
 Datation Elapsed Time 3 (DET3)
 Datation Elapsed Time 4 (DET4)
 Datation Preamble Field (DPF)
 Delay Count (DC)
 Disable Sync (DS)
 External Datation 0 Elapsed Time 0 (ED0ET0)
 External Datation 0 Elapsed Time 1 (ED0ET1)
 External Datation 0 Elapsed Time 2 (ED0ET2)
 External Datation 0 Elapsed Time 3 (ED0ET3)
 External Datation 0 Elapsed Time 4 (ED0ET4)
 External Datation 0 Mask (EDM0)
 External Datation 0 Preamble Field (EDPF0)
 Interrupt Enable (IE)
 Latency Preamble Field (LPF)
 Time Stamp Elapsed Time 0 Rx (TR0)
 Time Stamp Elapsed Time 0 Tx (TT0)
 Time Stamp Elapsed Time 1 Rx (TR1)
 Time Stamp Elapsed Time 1 Tx (TT1)
 Time Stamp Elapsed Time 2 Rx (TR2)
 Time Stamp Elapsed Time 2 Tx (TT2)
 Time Stamp Elapsed Time 3 Rx (TR3)
 Time Stamp Elapsed Time 3 Tx (TT3)
 Time Stamp Elapsed Time 4 Rx (TR4)
 Time Stamp Elapsed Time 4 Tx (TT4)
 Time-Stamp Preamble Field Rx (TRPFRX)
 Time-Stamp SpaceWire Time-Code and Preamble Field Tx (TTPFTX)
file  spwtdp-regs.h
 This header file defines the SPWTDP register block interface.
struct  spwtdp
 This structure defines the SPWTDP register block memory map. More...
typedef struct spwtdp spwtdp
