RTEMS 6.1-rc2
schedulernodeimpl.h File Reference
This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are only used by the implementation. More...
#include <rtems/score/schedulernode.h>
#include <rtems/score/priorityimpl.h>
#define SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE(node)    RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority.Node.Node.Chain )
#define SCHEDULER_NODE_OF_WAIT_PRIORITY(node)    RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority )
#define SCHEDULER_PRIORITY_MAP(priority)   ( ( priority ) << 1 )
 Maps a priority value to support the append indicator.
#define SCHEDULER_PRIORITY_UNMAP(priority)   ( ( priority ) >> 1 )
 Returns the plain priority value.
#define SCHEDULER_PRIORITY_PURIFY(priority)    ( ( priority ) & ~( (Priority_Control) PRIORITY_GROUP_LAST ) )
 Clears the priority append indicator bit.
#define SCHEDULER_PRIORITY_APPEND(priority)    ( ( priority ) | ( (Priority_Control) PRIORITY_GROUP_LAST ) )
 Returns the priority control with the append indicator bit set.
#define SCHEDULER_PRIORITY_IS_APPEND(priority)    ( ( ( priority ) & ( (Priority_Control) PRIORITY_GROUP_LAST ) ) != 0 )
 Returns true, if the item should be appended to its priority group, otherwise returns false and the item should be prepended to its priority group.
